REST API reference
Complete a consistency group snapshot operation
Completes a consistency group snapshot operation by committing an existing snapshot to disk, ensuring the data is preserved and available for future use.
HTTP method and endpoint
PATCH /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Completes a snapshot operation of a consistency group.
Example
Completing a snapshot operation
The following example shows how to complete the snapshot operation by committing an existing snapshot to disk:
curl -X PATCH https://<mgmt-ip>/api/application/consistency-groups/a8d0626a-17a0-11eb-b141-005056acd498/snapshots/92c6c770-17a1-11eb-b141-005056acd498?action=commit
Response:
Modifying the SnapLock expiry time of a snapshot in SnapLock for SnapVault
The following example shows how to modify the SnapLock expiry time of a locked snapshot in SnapLock for SnapVault destination:
curl -X PATCH 'https://<mgmt-ip>/api/application/consistency-groups/a8d0626a-17a0-11eb-b141-005056acd498/snapshots/92c6c770-17a1-11eb-b141-005056acd498' -d '{"snaplock.expiry_time" : "2/28/2024 10:11:10 +05:30"}' -H "accept: application/hal+json"
Response:
  "job": {
    "uuid": "8c9cabf3-0a88-11ec-a449-005056bbcf9f",
        "href": "/api/cluster/jobs/8c9cabf3-0a88-11ec-a449-005056bbcf9f"
string
path
True
Unique identifier of the consistency group's snapshot for deletion.
uuid
string
path
True
Snapshot UUID.
action
string
query
False
Commits the snapshot. The commit must be called within the timeout value specified during POST. If the commit is not called within the specified time, then the snapshot create operation is aborted.
  • enum: ["commit"]
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
53411925
Failed to find a previously initiated two-phase snapshot operation for consistency group.
53412015
SnapLock expiry time cannot be before the current expiry time.
53412016
Snapshot is not retained by SnapLock.
53412017
The operation is not supported on this platform.</personalities>
Name Type Description
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
