Complete a consistency group Snapshot copy operation
Completes a Snapshot copy operation for a consistency group by committing an existing Snapshot copy to disk.
HTTP method and endpoint
PATCH /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Completes a Snapshot copy operation of a consistency group.
Example
Completing a Snapshot copy operation
The following example shows how to complete the Snapshot copy operation by committing an existing Snapshot copy to disk:
curl -X PATCH https://<mgmt-ip>/api/application/consistency-groups/a8d0626a-17a0-11eb-b141-005056acd498/snapshots/92c6c770-17a1-11eb-b141-005056acd498?action=commit
Response:
consistency_group.uuid |
string |
path |
True |
Unique identifier of the consistency group's Snapshot copy for deletion. |
uuid |
string |
path |
True |
Snapshot copy UUID. |
action |
string |
query |
False |
Commits the Snapshot copy. The commit must be called within the timeout value specified during POST. If the commit is not called within the specified time, then the Snapshot copy create operation is aborted.
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53411925 |
Failed to find a previously initiated two-phase Snapshot copy operation for consistency group. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
