REST API reference
Updates an ipspace object
PATCH /network/ipspaces/{uuid}
Introduced In: 9.6
Updates an IPspace object.
  • network ipspace rename
uuid
string
path
True
IPspace UUID
Request Body
Name Type Description
name
string
IPspace name
uuid
string
The UUID that uniquely identifies the IPspace.
Example request
  "name": "ipspace1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1377259
System-defined IPspaces cannot be modified or removed.
string
ipspace
name
string
IPspace name
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
