Update an IPspace object
PATCH /network/ipspaces/{uuid}
Introduced In: 9.6
Updates an IPspace object.
Related ONTAP commands
network ipspace rename
uuid |
string |
path |
True |
IPspace UUID |
Request Body
| Name | Type | Description |
name |
string |
IPspace name |
uuid |
string |
The UUID that uniquely identifies the IPspace. |
Example request
"name": "ipspace1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1377256 |
Another IPspace with the same name exists. |
1377259 |
System-defined IPspaces cannot be modified or removed. |
9240587 |
IPspace name cannot be empty. |
9240588 |
The specified name is too long. |
9240589 |
Invalid character in specified name. |
9240591 |
The specified name is already in use. |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
