REST API reference
Update an IPspace object
PATCH /network/ipspaces/{uuid}
Introduced In: 9.6
Updates an IPspace object.
  • network ipspace rename
  • network ipspace modify
uuid
string
path
True
IPspace UUID
Request Body
Name Type Description
name
string
IPspace name
tcp_stack
string
The TCP stack used by the IPspace.
uuid
string
The UUID that uniquely identifies the IPspace.
Example request
  "name": "ipspace1",
  "tcp_stack": "freebsd",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1377256
Another IPspace with the same name exists.
1377259
System-defined IPspaces cannot be modified or removed.
1966449
Invalid IPspace name in MetroCluster configurations.
9240587
IPspace name cannot be empty.
9240588
The specified name is too long.
9240589
Invalid character in specified name.
9240590
Invalid name, the name is reserved by the system.
9240591
Invalid name. The name is already in use by a cluster node, Vserver, or it is the name of the local cluster.
string
ipspace
name
string
IPspace name
tcp_stack
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
