Update a tape device
Updates a specific tape device to modify its configuration or settings as needed. This operation is useful when you need to adjust the tape device parameters or status.
HTTP method and endpoint
PATCH /storage/tape-devices/{node.uuid}/{device_id}
Introduced in
ONTAP 9.11
Related ONTAP commands
storage tape alias-set -
storage tape alias-clear -
storage tape online -
storage tape offline -
storage tape position
Learn more
node.uuid |
string |
path |
True |
Node UUID |
device_id |
string |
path |
True |
Device ID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
aliases |
array[aliases] |
block_number |
integer |
Block number. |
density |
string |
Density. |
description |
string |
device_id |
string |
device_state |
string |
Operational state of the device. |
file_number |
integer |
File number. |
interface |
string |
Device interface type. |
node |
online |
boolean |
position |
reservation_type |
string |
residual_count |
integer |
Residual count of the last I/O operation. |
serial_number |
string |
type |
string |
Device type. |
wwnn |
string |
World Wide Node Name. |
wwpn |
string |
World Wide Port Name. |
Example request
"aliases": [
"mapping": "SN[10WT000933]",
"name": "st6"
"block_number": 0,
"density": "low",
"description": "QUANTUM LTO-8 ULTRIUM",
"device_id": "1a.0",
"device_state": "read_write_enabled",
"file_number": 0,
"interface": "sas",
"node": {
"name": "node1",
"position": {
"count": 5,
"operation": "rewind"
"reservation_type": "off",
"residual_count": 0,
"serial_number": "10WT00093",
"type": "tape",
"wwnn": "500507631295741c",
"wwpn": "500507631295741c"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
11403264 |
Tape operation " |
11403265 |
Tape operation " |
11403266 |
Internal error. Unknown tape parameter for tape device " |
11403267 |
Tape device " |
11403268 |
No tape loaded for " |
11403269 |
Tape device " |
11403270 |
Tape alias name " |
11403271 |
The format of the tape alias name " |
11403273 |
Internal error. Tape alias name " |
11403274 |
Internal error. Tape alias operation " |
11403275 |
Tape alias name " |
11403277 |
Tape device " |
11403278 |
Invalid count value specified with operation " |
alias
mapping |
string |
This field will no longer be supported in a future release. Use aliases.mapping instead. |
name |
string |
This field will no longer be supported in a future release. Use aliases.name instead. |
aliases
mapping |
string |
Alias mapping. |
name |
string |
Alias name. |
device_names
no_rewind_device |
string |
Device name for no rewind. |
rewind_device |
string |
Device name for rewind. |
unload_reload_device |
string |
Device name for unload or reload operations. |
href |
string |
_links
node
name |
string |
uuid |
string |
position
count |
integer |
Number of times to run position operation. |
operation |
string |
Position operation. |
storage_port
name |
string |
Initiator port. |
tape_device
aliases |
array[aliases] |
block_number |
integer |
Block number. |
density |
string |
Density. |
description |
string |
device_id |
string |
device_state |
string |
file_number |
integer |
File number. |
interface |
string |
node |
online |
boolean |
position |
reservation_type |
string |
residual_count |
integer |
serial_number |
string |
type |
string |
Device type. |
wwnn |
string |
wwpn |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
