Update a tape device
PATCH /storage/tape-devices/{node.uuid}/{device_id}
Introduced In: 9.11
Updates a specific tape device.
Related ONTAP commands
storage tape alias-set -
storage tape alias-clear -
storage tape online -
storage tape offline -
storage tape position
Learn more
node.uuid  |
string  |
path  |
True  |
Node UUID  |
device_id  |
string  |
path  |
True  |
Device ID  |
return_timeout  |
integer  |
query  |
False  |
Request Body
| Name | Type | Description |
alias  |
aliases  |
array[aliases]  |
block_number  |
integer  |
Block number.  |
density  |
string  |
Density.  |
description  |
string  |
device_id  |
string  |
device_names  |
array[device_names]  |
device_state  |
string  |
Operational state of the device.  |
file_number  |
integer  |
File number.  |
formats  |
array[string]  |
Tape cartridge format.  |
interface  |
string  |
Device interface type.  |
node  |
online  |
boolean  |
position  |
reservation_type  |
string  |
residual_count  |
integer  |
Residual count of the last I/O operation.  |
serial_number  |
string  |
storage_port  |
type  |
string  |
Device type.  |
wwnn  |
string  |
World Wide Node Name.  |
wwpn  |
string  |
World Wide Port Name.  |
Example request
  "alias": {
    "mapping": "SN[10WT000933]",
    "name": "st6"
  "aliases": [
      "name": "st6"
  "block_number": 0,
  "density": "low",
  "description": "QUANTUM LTO-8 ULTRIUM",
  "device_id": "1a.0",
  "device_names": [
      "no_rewind_device": "nrst6l",
      "rewind_device": "rst6l",
      "unload_reload_device": "urst6l"
  "device_state": "read_write_enabled",
  "file_number": 0,
  "formats": [
    "LTO-7 6TB",
    "LTO-7 15TB Compressed",
    "LTO-8 12TB",
    "LTO-8 30TB Compressed"
  "interface": "sas",
  "node": {
    "name": "node1",
  "position": {
    "count": 5,
    "operation": "rewind"
  "reservation_type": "off",
  "residual_count": 0,
  "serial_number": "10WT00093",
  "storage_port": {
    "name": "2b"
  "type": "tape",
  "wwnn": "500507631295741c",
  "wwpn": "500507631295741c"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
11403264  |
Tape operation "  |
11403265  |
Tape operation  "  |
11403266  |
Internal error. Unknown tape parameter for tape device "  |
11403267  |
Tape device "  |
11403268  |
No tape loaded for "  |
11403269  |
Tape device "  |
11403270  |
Tape alias name "  |
11403271  |
The format of the tape alias name "  |
11403273  |
Internal error. Tape alias name "  |
11403274  |
Internal error. Tape alias operation "  |
11403275  |
Tape alias name "  |
11403277  |
Tape device "  |
11403278  |
Invalid count value specified with operation "  |
alias
mapping  |
string  |
This field will no longer be supported in a future release. Use aliases.mapping instead.  |
name  |
string  |
This field will no longer be supported in a future release. Use aliases.name instead.  |
aliases
mapping  |
string  |
Alias mapping.  |
name  |
string  |
Alias name.  |
device_names
no_rewind_device  |
string  |
Device name for no rewind.  |
rewind_device  |
string  |
Device name for rewind.  |
unload_reload_device  |
string  |
Device name for unload or reload operations.  |
href  |
string  |
_links
node
name  |
string  |
uuid  |
string  |
position
count  |
integer  |
Number of times to run position operation.  |
operation  |
string  |
Position operation.  |
storage_port
name  |
string  |
Initiator port.  |
tape_device
alias  |
aliases  |
array[aliases]  |
block_number  |
integer  |
Block number.  |
density  |
string  |
Density.  |
description  |
string  |
device_id  |
string  |
device_names  |
device_state  |
string  |
file_number  |
integer  |
File number.  |
formats  |
array[string]  |
interface  |
string  |
node  |
online  |
boolean  |
position  |
reservation_type  |
string  |
residual_count  |
integer  |
serial_number  |
string  |
storage_port  |
type  |
string  |
Device type.  |
wwnn  |
string  |
wwpn  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
