REST API reference
Update a tape device
Updates a specific tape device to modify its configuration or settings. Use this operation to adjust device parameters as needed for your storage environment.
HTTP method and endpoint
PATCH /storage/tape-devices/{node.uuid}/{device_id}
Introduced in
ONTAP 9.11
  • storage tape alias-set
  • storage tape alias-clear
  • storage tape online
  • storage tape offline
  • storage tape position
node.uuid
string
path
True
Node UUID
device_id
string
path
True
Device ID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
alias
alias
aliases
array[aliases]
block_number
integer
Block number.
density
string
Density.
description
string
device_id
string
device_names
array[device_names]
device_state
string
Operational state of the device.
file_number
integer
File number.
formats
array[string]
Tape cartridge format.
interface
string
Device interface type.
node
node
online
boolean
position
position
reservation_type
string
residual_count
integer
Residual count of the last I/O operation.
serial_number
string
storage_port
storage_port
type
string
Device type.
wwnn
string
World Wide Node Name.
wwpn
string
World Wide Port Name.
Example request
  "alias": {
    "mapping": "SN[10WT000933]",
    "name": "st6"
  "aliases": [
      "name": "st6"
  "block_number": 0,
  "density": "low",
  "description": "QUANTUM LTO-8 ULTRIUM",
  "device_id": "1a.0",
  "device_names": [
      "no_rewind_device": "nrst6l",
      "rewind_device": "rst6l",
      "unload_reload_device": "urst6l"
  "device_state": "read_write_enabled",
  "file_number": 0,
  "formats": [
    "LTO-7 6TB",
    "LTO-7 15TB Compressed",
    "LTO-8 12TB",
    "LTO-8 30TB Compressed"
  "interface": "sas",
  "node": {
    "name": "node1",
  "position": {
    "count": 5,
    "operation": "rewind"
  "reservation_type": "off",
  "residual_count": 0,
  "serial_number": "10WT00093",
  "storage_port": {
    "name": "2b"
  "type": "tape",
  "wwnn": "500507631295741c",
  "wwpn": "500507631295741c"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
11403264
Tape operation "\" failed on tape device \"\". This may indicate tape reached end of data, a hardware error, an illegal request, an invalid name format, or an aborted command.
11403265
Tape operation "\" failed because it encountered an unexpected file mark on tape device \"\".
11403266
Internal error. Unknown tape parameter for tape device "\".
11403267
Tape device "\" is busy.
11403268
No tape loaded for "\" operation on tape drive \"\".
11403269
Tape device "\" unknown.
11403270
Tape alias name "\" already exists.
11403271
The format of the tape alias name "\" is invalid. Use \"st\" or \"mc\" followed by one or more digits.
11403273
Internal error. Tape alias name "\" not saved.
11403274
Internal error. Tape alias operation "\" for alias name \"\" failed.
11403275
Tape alias name "\" not found.
11403277
Tape device "\" is reserved by another host.
11403278
Invalid count value specified with operation "\". Valid values are from 0 to {1}.
alias
mapping
string
This field will no longer be supported in a future release. Use aliases.mapping instead.
name
string
This field will no longer be supported in a future release. Use aliases.name instead.
aliases
mapping
string
Alias mapping.
name
string
Alias name.
device_names
no_rewind_device
string
Device name for no rewind.
rewind_device
string
Device name for rewind.
string
Device name for unload or reload operations.
string
node
name
string
uuid
string
position
count
integer
Number of times to run position operation.
operation
string
Position operation.
storage_port
name
string
Initiator port.
tape_device
alias
alias
aliases
array[aliases]
block_number
integer
Block number.
density
string
Density.
description
string
device_id
string
device_names
array[device_names]
device_state
string
file_number
integer
File number.
formats
array[string]
interface
string
node
node
online
boolean
position
position
reservation_type
string
residual_count
integer
serial_number
string
storage_port
storage_port
type
string
Device type.
wwnn
string
wwpn
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
