REST API reference
Update the web services security configuration
Updates the web services security configuration to modify security settings according to your requirements.
HTTP method and endpoint
PATCH /svm/svms/{svm.uuid}/web
Introduced in
ONTAP 9.10
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
certificate
certificate
Certificate used by cluster and node management interfaces for TLS connection requests.
client_enabled
boolean
Indicates whether client authentication is enabled.
ocsp_enabled
boolean
Indicates whether online certificate status protocol verification is enabled.
svm
svm
Example request
  "certificate": {
    "name": "cert1",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
9830442
Client authentication cannot be enabled without a client ca certificate.
9830488
The certificate is not a "server" certificate.
9830489
The certificate does not exist for the given SVM.
string
certificate
name
string
Certificate name
uuid
string
Certificate UUID
svm
name
string
The name of the SVM.
uuid
string
web_svm
certificate
certificate
client_enabled
boolean
ocsp_enabled
boolean
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
