REST API reference
Update the web services security configuration
PATCH /svm/svms/{svm.uuid}/web
Introduced In: 9.10
Updates the web services security configuration.
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
certificate
certificate
Certificate used by cluster and node management interfaces for TLS connection requests.
client_enabled
boolean
Indicates whether client authentication is enabled.
ocsp_enabled
boolean
Indicates whether online certificate status protocol verification is enabled.
svm
svm
Example request
  "certificate": {
    "name": "cert1",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
9830442
Client authentication cannot be enabled without a client ca certificate.
9830488
The certificate is not a "server" certificate.
9830489
The certificate does not exist for the given SVM.
string
certificate
name
string
Certificate name
uuid
string
Certificate UUID
svm
name
string
uuid
string
web_svm
certificate
certificate
client_enabled
boolean
ocsp_enabled
boolean
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
