Update the web services security configuration
Updates the web services security configuration to maintain or enhance the security protocols for your web services environment.
HTTP method and endpoint
PATCH /svm/svms/{svm.uuid}/web
Introduced in
ONTAP 9.10
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
certificate |
Certificate used by cluster and node management interfaces for TLS connection requests. |
client_enabled |
boolean |
Indicates whether client authentication is enabled. |
ocsp_enabled |
boolean |
Indicates whether online certificate status protocol verification is enabled. |
svm |
Example request
"certificate": {
"name": "cert1",
"svm": {
"name": "svm1",
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9830442 |
Client authentication cannot be enabled without a client ca certificate. |
9830488 |
The certificate is not a "server" certificate. |
9830489 |
The certificate does not exist for the given SVM. |
href |
string |
_links
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
svm
name |
string |
uuid |
string |
web_svm
certificate |
client_enabled |
boolean |
ocsp_enabled |
boolean |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
