Create a cloud target
Creates a cloud target to configure ONTAP for cloud-based storage. This setup is essential for integrating cloud services with your ONTAP environment.
HTTP method and endpoint
POST /cloud/targets
Introduced in
ONTAP 9.6
Required properties
name- Name for the cloud target. -
owner- Owner of the target: fabricpool, snapmirror. -
provider_type- Type of cloud provider: AWS_S3, Azure_Cloud, SGWS, IBM_COS, AliCloud, GoogleCloud, ONTAP_S3. -
server- Fully qualified domain name of the object store server. Required whenprovider_typeis one of the following: SGWS, IBM_COS, AliCloud. -
container- Data bucket/container name. -
access_key- Access key ID ifprovider_typeis not Azure_Cloud andauthentication_typeis key. -
secret_password- Secret access key ifprovider_typeis not Azure_Cloud andauthentication_typeis key. -
azure_account- Azure account ifprovider_typeis Azure_Cloud. -
azure_private_key- Azure access key ifprovider_typeis Azure_Cloud. -
cap_url- Full URL of the request to a CAP server for retrieving temporary credentials ifauthentication_typeis cap. -
snapmirror_use- Use of the cloud target ifowneris snapmirror: data, metadata.
Recommended optional properties
authentication_type- Authentication used to access the target: key, cap, ec2_iam, gcp_sa, azure_msi. -
ssl_enabled- SSL/HTTPS enabled or disabled. -
port- Port number of the object store that ONTAP uses when establishing a connection. -
ipspace- IPspace to use in order to reach the cloud target. -
use_http_proxy- Use the HTTP proxy when connecting to the object store server. -
azure_sas_token- Shared access signature to grant limited access to Azure storage account resources. -
svm.nameorsvm.uuid- Name or UUID of SVM ifowneris snapmirror.
Default property values
authentication_type -
ec2_iam - if running in Cloud Volumes ONTAP in AWS
gcp_sa - if running in Cloud Volumes ONTAP in GCP
azure_msi - if running in Cloud Volumes ONTAP in Azure
key - in all other cases.
server -
s3.amazonaws.com - if
provider_typeis AWS_S3 -
blob.core.windows.net - if
provider_typeis Azure_Cloud -
storage.googleapis.com - if
provider_typeis GoogleCloud -
ssl_enabled- true -
port -
443 if
ssl_enabledis true -
80 if
ssl_enabledis false andprovider_typeis not SGWS -
8084 if
ssl_enabledis false andprovider_typeis SGWS -
ipspace- Default -
certificate_validation_enabled- true -
ignore_warnings- false -
check_only- false -
use_http_proxy- false -
server_side_encryption -
none - if
provider_typeis ONTAP_S3 -
sse_s3 - if
provider_typeis not ONTAP_S3 -
url_style -
path_style - if
provider_typeis neither AWS_S3 nor AliCloud -
virtual_hosted_style - if
provider_typeis either AWS_S3 or _AliCloud_
Related ONTAP commands
storage aggregate object-store config create
ignore_warnings |
boolean |
query |
False |
Specifies whether or not warning codes should be ignored. |
check_only |
boolean |
query |
False |
Do not create the target configuration, only check that the POST request succeeds. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_links |
access_key |
string |
Access key ID for AWS_S3 and other S3 compatible provider types. |
authentication_type |
string |
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST. |
azure_account |
string |
Azure account |
azure_private_key |
string |
Azure access key |
azure_sas_token |
string |
Shared access signature token to access Azure containers and blobs. |
cap_url |
string |
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword, and session token) for accessing the object store. |
certificate_validation_enabled |
boolean |
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
cluster |
container |
string |
Data bucket/container name. For FabricLink, a wildcard character "*" can also be specified to indicate that all the buckets in an SVM can use the same target information. However, for containers other than ONTAP, an exact name should be specified.
ipspace |
IPspace to use in order to reach the cloud target. |
name |
string |
Cloud target name |
owner |
string |
Owner of the target. Allowed values are FabricPool, SnapMirror or S3_SnapMirror. A target can be used by only one feature. |
port |
integer |
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
provider_type |
string |
Type of cloud provider. Allowed values depend on owner type. For FabricPool, AliCloud, AWS_S3, Azure_Cloud, GoggleCloud, IBM_COS, SGWS, and ONTAP_S3 are allowed. For SnapMirror, the valid values are AWS_S3 or SGWS. For FabricLink, AWS_S3, SGWS, S3_Compatible, S3EMU, LOOPBACK and ONTAP_S3 are allowed.
scope |
string |
If the cloud target is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster. |
secret_password |
string |
Secret access key for AWS_S3 and other S3 compatible provider types. |
server |
string |
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3- |
server_side_encryption |
string |
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. This is an advanced property. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
snapmirror_use |
string |
Use of the cloud target by SnapMirror. |
ssl_enabled |
boolean |
SSL/HTTPS enabled or not |
svm |
This field is only applicable when used for SnapMirror and FabricLink. For POST and PATCH, SVM information is required for SnapMirror and FabricLink targets and not allowed for FabricPool targets. |
url_style |
string |
URL style used to access S3 bucket. |
use_http_proxy |
boolean |
Use HTTP proxy when connecting to the object store. |
used |
integer |
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes. |
uuid |
string |
Cloud target UUID |
Example request
"access_key": "string",
"authentication_type": "string",
"azure_account": "string",
"azure_private_key": "string",
"azure_sas_token": "string",
"cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
"cluster": {
"name": "string",
"uuid": "string"
"container": "bucket1",
"ipspace": {
"name": "exchange",
"name": "string",
"owner": "string",
"provider_type": "string",
"scope": "string",
"secret_password": "string",
"server": "string",
"server_side_encryption": "string",
"snapmirror_use": "string",
"svm": {
"name": "svm1",
"url_style": "string",
"used": 0,
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default, Error
href |
string |
_links
cluster
name |
string |
The name of the cluster that owns the cloud target. For POST, this accepts the name of the peer cluster only if the cluster is in switchover state. |
uuid |
string |
The UUID of the cluster that owns the cloud target. For POST, this accepts the UUID of the peer cluster only if the cluster is in switchover state. |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cloud_target
_links |
access_key |
string |
string |
azure_account |
string |
Azure account |
azure_private_key |
string |
Azure access key |
azure_sas_token |
string |
cap_url |
string |
boolean |
cluster |
container |
string |
ipspace |
name |
string |
Cloud target name |
owner |
string |
port |
integer |
provider_type |
string |
scope |
string |
secret_password |
string |
server |
string |
string |
snapmirror_use |
string |
ssl_enabled |
boolean |
svm |
url_style |
string |
use_http_proxy |
boolean |
used |
integer |
uuid |
string |
Cloud target UUID |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
