REST API reference
Create a cloud target
Creates a cloud target to enable ONTAP to store data in various cloud providers. This operation is typically used when configuring object storage for data tiering or replication workflows.
HTTP method and endpoint
POST /cloud/targets
Introduced in
ONTAP 9.6
Required properties
  • name - Name for the cloud target.
  • owner - Owner of the target: fabricpool, snapmirror.
  • provider_type - Type of cloud provider: AWS_S3, Azure_Cloud, SGWS, IBM_COS, AliCloud, GoogleCloud, ONTAP_S3.
  • server - Fully qualified domain name of the object store server. Required when provider_type is one of the following: SGWS, IBM_COS, AliCloud.
  • container - Data bucket/container name.
  • access_key - Access key ID if provider_type is not Azure_Cloud and authentication_type is key.
  • secret_password - Secret access key if provider_type is not Azure_Cloud and authentication_type is key.
  • azure_account - Azure account if provider_type is Azure_Cloud.
  • azure_private_key - Azure access key if provider_type is Azure_Cloud.
  • cap_url - Full URL of the request to a CAP server for retrieving temporary credentials if authentication_type is cap.
  • svm.name or svm.uuid - Name or UUID of SVM if owner is snapmirror.
  • snapmirror_use - Use of the cloud target if owner is snapmirror: data, metadata.
  • authentication_type - Authentication used to access the target: key, cap, ec2_iam, gcp_sa, azure_msi.
  • ssl_enabled - SSL/HTTPS enabled or disabled.
  • port - Port number of the object store that ONTAP uses when establishing a connection.
  • ipspace - IPspace to use in order to reach the cloud target.
  • use_http_proxy - Use the HTTP proxy when connecting to the object store server.
Default property values
  • ec2_iam - if running in Cloud Volumes ONTAP in AWS
  • gcp_sa - if running in Cloud Volumes ONTAP in GCP
  • azure_msi - if running in Cloud Volumes ONTAP in Azure
  • key - in all other cases.
  • server
  • s3.amazonaws.com - if provider_type is AWS_S3
  • blob.core.windows.net - if provider_type is Azure_Cloud
  • storage.googleapis.com - if provider_type is GoogleCloud
  • ssl_enabled - true
  • port
  • 443 if ssl_enabled is true
  • 80 if ssl_enabled is false and provider_type is not SGWS
  • 8084 if ssl_enabled is false and provider_type is SGWS
  • ipspace - Default
  • certificate_validation_enabled - true
  • ignore_warnings - false
  • check_only - false
  • use_http_proxy - false
  • server_side_encryption
  • none - if provider_type is ONTAP_S3
  • sse_s3 - if provider_type is not ONTAP_S3
  • url_style
  • path_style - if provider_type is neither AWS_S3 nor AliCloud
  • virtual_hosted_style - if provider_type is either AWS_S3 or _AliCloud_
  • storage aggregate object-store config create
ignore_warnings
boolean
query
False
Specifies whether or not warning codes should be ignored.
check_only
boolean
query
False
Do not create the target configuration, only check that the POST request succeeds.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
access_key
string
Access key ID for AWS_S3 and other S3 compatible provider types.
authentication_type
string
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST.
azure_account
string
Azure account
azure_private_key
string
Azure access key
cap_url
string
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword, and session token) for accessing the object store.
boolean
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
  • Introduced in: 9.6
cluster
cluster
container
string
Data bucket/container name. For FabricLink, a wildcard character "*" can also be specified to indicate that all the buckets in an SVM can use the same target information. However, for containers other than ONTAP, an exact name should be specified.
  • example: bucket1
  • readCreate: 1
ipspace
ipspace
name
string
Cloud target name
owner
string
Owner of the target. Allowed values are FabricPool, SnapMirror or S3_SnapMirror. A target can be used by only one feature.
port
integer
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
provider_type
string
Type of cloud provider. Allowed values depend on owner type. For FabricPool, AliCloud, AWS_S3, Azure_Cloud, GoggleCloud, IBM_COS, SGWS, and ONTAP_S3 are allowed. For SnapMirror, the valid values are AWS_S3 or SGWS. For FabricLink, AWS_S3, SGWS, S3_Compatible, S3EMU, LOOPBACK and ONTAP_S3 are allowed.
  • readCreate: 1
secret_password
string
Secret access key for AWS_S3 and other S3 compatible provider types.
server
string
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3-.amazonaws.com, for example, s3-us-west-2.amazonaws.com. The region of the server and the bucket must match. For Azure, if the server is a "blob.core.windows.net" or a "blob.core.usgovcloudapi.net", then a value of azure-account followed by a period is added in front of the server.
string
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. This is an advanced property. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
  • enum: ["none", "sse_s3"]
  • Introduced in: 9.7
snapmirror_use
string
Use of the cloud target by SnapMirror.
ssl_enabled
boolean
SSL/HTTPS enabled or not
svm
svm
This field is only applicable when used for SnapMirror and FabricLink. For POST and PATCH, SVM information is required for SnapMirror and FabricLink targets and not allowed for FabricPool targets.
url_style
string
URL style used to access S3 bucket.
use_http_proxy
boolean
Use HTTP proxy when connecting to the object store.
used
integer
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes.
uuid
string
Cloud target UUID
Example request
  "access_key": "string",
  "authentication_type": "string",
  "azure_account": "string",
  "azure_private_key": "string",
  "cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
  "cluster": {
    "name": "string",
    "uuid": "string"
  "container": "bucket1",
  "ipspace": {
    "name": "exchange",
  "name": "string",
  "owner": "string",
  "provider_type": "string",
  "secret_password": "string",
  "server": "string",
  "server_side_encryption": "string",
  "snapmirror_use": "string",
  "svm": {
    "name": "svm1",
  "url_style": "string",
  "used": 0,
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
cluster
name
string
The name of the cluster that owns the cloud target. For POST, this accepts the name of the peer cluster only if the cluster is in switchover state.
uuid
string
The UUID of the cluster that owns the cloud target. For POST, this accepts the UUID of the peer cluster only if the cluster is in switchover state.
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
svm
name
string
The name of the SVM.
uuid
string
cloud_target
access_key
string
authentication_type
string
azure_account
string
Azure account
azure_private_key
string
Azure access key
cap_url
string
boolean
cluster
cluster
container
string
  • example: bucket1
  • readCreate: 1
ipspace
ipspace
name
string
Cloud target name
owner
string
port
integer
provider_type
string
  • readCreate: 1
secret_password
string
server
string
string
snapmirror_use
string
ssl_enabled
boolean
svm
svm
url_style
string
use_http_proxy
boolean
used
integer
uuid
string
Cloud target UUID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
