Create a cloud target
POST /cloud/targets
Introduced In: 9.6
Creates a cloud target.
Required properties
name- Name for the cloud target. -
owner- Owner of the target: fabricpool, snapmirror. -
provider_type- Type of cloud provider: AWS_S3, Azure_Cloud, SGWS, IBM_COS, AliCloud, GoogleCloud, ONTAP_S3. -
server- Fully qualified domain name of the object store server. Required whenprovider_typeis one of the following: SGWS, IBM_COS, AliCloud. -
container- Data bucket/container name. -
access_key- Access key ID ifprovider_typeis not Azure_Cloud andauthentication_typeis key. -
secret_password- Secret access key ifprovider_typeis not Azure_Cloud andauthentication_typeis key. -
azure_account- Azure account ifprovider_typeis Azure_Cloud. -
azure_private_key- Azure access key ifprovider_typeis Azure_Cloud. -
cap_url- Full URL of the request to a CAP server for retrieving temporary credentials ifauthentication_typeis cap. -
svm.nameorsvm.uuid- Name or UUID of SVM ifowneris snapmirror. -
snapmirror_use- Use of the cloud target ifowneris snapmirror: data, metadata.
Recommended optional properties
authentication_type- Authentication used to access the target: key, cap, ec2_iam, gcp_sa, azure_msi. -
ssl_enabled- SSL/HTTPS enabled or disabled. -
port- Port number of the object store that ONTAP uses when establishing a connection. -
ipspace- IPspace to use in order to reach the cloud target. -
use_http_proxy- Use the HTTP proxy when connecting to the object store server.
Default property values
authentication_type -
ec2_iam - if running in Cloud Volumes ONTAP in AWS
gcp_sa - if running in Cloud Volumes ONTAP in GCP
azure_msi - if running in Cloud Volumes ONTAP in Azure
key - in all other cases.
server -
s3.amazonaws.com - if
provider_typeis AWS_S3 -
blob.core.windows.net - if
provider_typeis Azure_Cloud -
storage.googleapis.com - if
provider_typeis GoogleCloud -
ssl_enabled- true -
port -
443 if
ssl_enabledis true andprovider_typeis not SGWS -
8082 if
ssl_enabledis true andprovider_typeis SGWS -
80 if
ssl_enabledis false andprovider_typeis not SGWS -
8084 if
ssl_enabledis false andprovider_typeis SGWS -
ipspace- Default -
certificate_validation_enabled- true -
ignore_warnings- false -
check_only- false -
use_http_proxy- false -
server_side_encryption -
none - if
provider_typeis ONTAP_S3 -
sse_s3 - if
provider_typeis not ONTAP_S3 -
url_style -
path_style - if
provider_typeis neither AWS_S3 nor AliCloud -
virtual_hosted_style - if
provider_typeis either AWS_S3 or _AliCloud_
Related ONTAP commands
storage aggregate object-store config create
ignore_warnings  |
boolean  |
query  |
False  |
Specifies whether or not warning codes should be ignored.  |
check_only  |
boolean  |
query  |
False  |
Do not create the target configuration, only check that the POST request succeeds.  |
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
access_key  |
string  |
Access key ID for AWS_S3 and other S3 compatible provider types.  |
authentication_type  |
string  |
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST.  |
azure_account  |
string  |
Azure account  |
azure_private_key  |
string  |
Azure access key  |
cap_url  |
string  |
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword, and session token) for accessing the object store.  |
certificate_validation_enabled  |
boolean  |
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
cluster  |
container  |
string  |
Data bucket/container name  |
ipspace  |
IPspace to use in order to reach the cloud target.  |
name  |
string  |
Cloud target name  |
owner  |
string  |
Owner of the target. Allowed values are FabricPool or SnapMirror. A target can be used by only one feature.  |
port  |
integer  |
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
provider_type  |
string  |
Type of cloud provider. Allowed values depend on owner type. For FabricPool, AliCloud, AWS_S3, Azure_Cloud, GoggleCloud, IBM_COS, SGWS, and ONTAP_S3 are allowed. For SnapMirror, the valid values are AWS_S3 or SGWS.
secret_password  |
string  |
Secret access key for AWS_S3 and other S3 compatible provider types.  |
server  |
string  |
Fully qualified domain name of the object store server. Required on POST.  For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3-  |
server_side_encryption  |
string  |
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. This is an advanced property. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
snapmirror_use  |
string  |
Use of the cloud target by SnapMirror.  |
ssl_enabled  |
boolean  |
SSL/HTTPS enabled or not  |
svm  |
This field is only applicable when used for SnapMirror. For POST and PATCH, SVM information is required for SnapMirror targets and not allowed for FabricPool targets.  |
url_style  |
string  |
URL style used to access S3 bucket.  |
use_http_proxy  |
boolean  |
Use HTTP proxy when connecting to the object store.  |
used  |
integer  |
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes.  |
uuid  |
string  |
Cloud target UUID  |
Example request
  "access_key": "string",
  "authentication_type": "string",
  "azure_account": "string",
  "azure_private_key": "string",
  "cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
  "cluster": {
    "name": "string",
    "uuid": "string"
  "container": "bucket1",
  "ipspace": {
    "name": "exchange",
  "name": "string",
  "owner": "string",
  "provider_type": "string",
  "secret_password": "string",
  "server": "string",
  "server_side_encryption": "string",
  "snapmirror_use": "string",
  "svm": {
    "name": "svm1",
  "url_style": "string",
  "used": 0,
  "uuid": "string"
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Status: Default, Error
href  |
string  |
_links
cluster
name  |
string  |
The name of the cluster that owns the cloud target. For POST, this accepts the name of the peer cluster only if the cluster is in switchover state.  |
uuid  |
string  |
The UUID of the cluster that owns the cloud target. For POST, this accepts the UUID of the peer cluster only if the cluster is in switchover state.  |
ipspace
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
svm
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
cloud_target
access_key  |
string  |
string  |
azure_account  |
string  |
Azure account  |
azure_private_key  |
string  |
Azure access key  |
cap_url  |
string  |
boolean  |
cluster  |
container  |
string  |
ipspace  |
name  |
string  |
Cloud target name  |
owner  |
string  |
port  |
integer  |
provider_type  |
string  |
secret_password  |
string  |
server  |
string  |
string  |
snapmirror_use  |
string  |
ssl_enabled  |
boolean  |
svm  |
url_style  |
string  |
use_http_proxy  |
boolean  |
used  |
integer  |
uuid  |
string  |
Cloud target UUID  |
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
