Creates a cloud target
owner- owner of the target: fabricpool, snapmirror -
provider_type- type of cloud provider: aws_s3, azure_cloud, sgws, ibm_cos, alicloud, googlecloud, ontap_s3 -
server- fully qualified domain name of the object store server required whenprovider_typeis one of the following: sgws, ibm_cos, alicloud -
container- data bucket/container name -
access_key- access key id ifprovider_typeis not azure_cloud andauthentication_typeis key -
secret_password- secret access key ifprovider_typeis not azure_cloud andauthentication_typeis key -
azure_account- azure account ifprovider_typeis azure_cloud -
azure_private_key- azure access key ifprovider_typeis azure_cloud -
cap_url- full url of the request to a cap server for retrieving temporary credentials ifauthentication_typeis cap -
svmnameorsvmuuid- name or uuid of svm ifowneris snapmirror -
snapmirror_use- use of the cloud target ifowneris snapmirror: data, metadata # recommended optional properties -
authentication_type- authentication used to access the target: key, cap, ec2_iam, gcp_sa -
ssl_enabled- ssl/https enabled or disabled -
port- port number of the object store that ontap uses when establishing a connection -
ipspace- ipspace to use in order to reach the cloud target -
use_http_proxy- use the http proxy when connecting to the object store server # default property values -
ec2_iam - if running in cloud volumes ontap in aws
gcp_sa - if running in cloud volumes ontap in gcp
key - in all other cases
server-
s3amazonawscom - if
provider_typeis aws_s3 -
blobcorewindowsnet - if
storagegoogleapiscom - if
provider_typeis googlecloud
ssl_enabled- true -
port-
443 if
ssl_enabledis true andprovider_typeis not sgws -
8082 if
ssl_enabledis true andprovider_typeis sgws -
80 if
ssl_enabledis false andprovider_typeis not sgws -
8084 if
ssl_enabledis false andprovider_typeis sgws
ipspace- default -
certificate_validation_enabled- true -
ignore_warnings- false -
check_only- false -
use_http_proxy- false -
server_side_encryption-
none - if
provider_typeis ontap_s3 -
sse_s3 - if
provider_typeis not ontap_s3 # related ontap commands
storage aggregate object-store config create
POST /cloud/targets
Creates a cloud target.
Required properties
name- Name for the cloud target. -
owner- Owner of the target: fabricpool, snapmirror. -
provider_type- Type of cloud provider: AWS_S3, Azure_Cloud, SGWS, IBM_COS, AliCloud, GoogleCloud, ONTAP_S3. -
server- Fully qualified domain name of the object store server. Required whenprovider_typeis one of the following: SGWS, IBM_COS, AliCloud. -
container- Data bucket/container name. -
access_key- Access key ID ifprovider_typeis not Azure_Cloud andauthentication_typeis key. -
secret_password- Secret access key ifprovider_typeis not Azure_Cloud andauthentication_typeis key. -
azure_account- Azure account ifprovider_typeis Azure_Cloud. -
azure_private_key- Azure access key ifprovider_typeis Azure_Cloud. -
cap_url- Full URL of the request to a CAP server for retrieving temporary credentials ifauthentication_typeis cap. -
svm.nameorsvm.uuid- Name or UUID of SVM ifowneris snapmirror. -
snapmirror_use- Use of the cloud target ifowneris snapmirror: data, metadata.
Recommended optional properties
authentication_type- Authentication used to access the target: key, cap, ec2_iam, gcp_sa. -
ssl_enabled- SSL/HTTPS enabled or disabled. -
port- Port number of the object store that ONTAP uses when establishing a connection. -
ipspace- IPspace to use in order to reach the cloud target. -
use_http_proxy- Use the HTTP proxy when connecting to the object store server.
Default property values
authentication_type -
ec2_iam - if running in Cloud Volumes ONTAP in AWS
gcp_sa - if running in Cloud Volumes ONTAP in GCP
key - in all other cases.
server -
s3.amazonaws.com - if
provider_typeis AWS_S3 -
blob.core.windows.net - if
provider_typeis Azure_Cloud -
storage.googleapis.com - if
provider_typeis GoogleCloud -
ssl_enabled- true -
port -
443 if
ssl_enabledis true andprovider_typeis not SGWS -
8082 if
ssl_enabledis true andprovider_typeis SGWS -
80 if
ssl_enabledis false andprovider_typeis not SGWS -
8084 if
ssl_enabledis false andprovider_typeis SGWS -
ipspace- Default -
check_only- false -
server_side_encryption -
none - if
provider_typeis ONTAP_S3 -
sse_s3 - if
provider_typeis not ONTAP_S3
Related ONTAP commands
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
ignore_warnings |
boolean |
query |
False |
Specifies whether or not warning codes should be ignored. |
check_only |
boolean |
query |
False |
Do not create the target configuration, only check that the POST request succeeds. |
Request Body
| Name | Type | Description |
_links |
access_key |
string |
Access key ID for AWS_S3 and other S3 compatible provider types. |
authentication_type |
string |
Authentication used to access the target. Snapmirror does not yet support CAP. Required in POST. |
azure_account |
string |
Azure account |
azure_private_key |
string |
Azure access key |
cap_url |
string |
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword, and session token) for accessing the object store. |
certificate_validation_enabled |
boolean |
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types. |
cluster |
container |
string |
Data bucket/container name |
ipspace |
IPspace to use in order to reach the cloud target. |
name |
string |
Cloud target name |
owner |
string |
Owner of the target. Allowed values are FabricPool or SnapMirror. A target can be used by only one feature. |
port |
integer |
Port number of the object store that ONTAP uses when establishing a connection. Required in POST. |
provider_type |
string |
Type of cloud provider. Allowed values depend on owner type. For FabricPool, AliCloud, AWS_S3, Azure_Cloud, GoggleCloud, IBM_COS, SGWS, and ONTAP_S3 are allowed. For SnapMirror, the valid values are AWS_S3 or SGWS.
secret_password |
string |
Secret access key for AWS_S3 and other S3 compatible provider types. |
server |
string |
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3- |
server_side_encryption |
string |
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. This is an advanced property. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
snapmirror_use |
string |
Use of the cloud target by SnapMirror. |
ssl_enabled |
boolean |
SSL/HTTPS enabled or not |
svm |
This field is only applicable when used for SnapMirror. For POST and PATCH, SVM information is required for SnapMirror targets and not allowed for FabricPool targets. |
use_http_proxy |
boolean |
Use HTTP proxy when connecting to the object store. |
used |
integer |
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes. |
uuid |
string |
Cloud target UUID |
Example request
"href": "/api/resourcelink"
"access_key": "string",
"authentication_type": "string",
"azure_account": "string",
"azure_private_key": "string",
"cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
"cluster": {
"name": "string",
"uuid": "string"
"container": "bucket1",
"ipspace": {
"name": "exchange",
"name": "string",
"owner": "string",
"provider_type": "string",
"secret_password": "string",
"server": "string",
"server_side_encryption": "string",
"snapmirror_use": "string",
"svm": {
"name": "svm1",
"used": 0,
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster
name |
string |
The name of the cluster that owns the cloud target. For POST, this accepts the name of the peer cluster only if the cluster is in switchover state. |
uuid |
string |
The UUID of the cluster that owns the cloud target. For POST, this accepts the UUID of the peer cluster only if the cluster is in switchover state. |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cloud_target
_links |
access_key |
string |
string |
azure_account |
string |
Azure account |
azure_private_key |
string |
Azure access key |
cap_url |
string |
boolean |
cluster |
container |
string |
ipspace |
name |
string |
Cloud target name |
owner |
string |
port |
integer |
provider_type |
string |
secret_password |
string |
server |
string |
string |
snapmirror_use |
string |
ssl_enabled |
boolean |
svm |
use_http_proxy |
boolean |
used |
integer |
uuid |
string |
Cloud target UUID |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
