REST API reference
Create a cloud target
POST /cloud/targets
Introduced In: 9.6
Creates a cloud target.
Required properties
  • name - Name for the cloud target.
  • owner - Owner of the target: fabricpool, snapmirror.
  • provider_type - Type of cloud provider: AWS_S3, Azure_Cloud, SGWS, IBM_COS, AliCloud, GoogleCloud, ONTAP_S3.
  • server - Fully qualified domain name of the object store server. Required when provider_type is one of the following: SGWS, IBM_COS, AliCloud.
  • container - Data bucket/container name.
  • access_key - Access key ID if provider_type is not Azure_Cloud and authentication_type is key.
  • secret_password - Secret access key if provider_type is not Azure_Cloud and authentication_type is key.
  • azure_account - Azure account if provider_type is Azure_Cloud.
  • azure_private_key - Azure access key if provider_type is Azure_Cloud.
  • cap_url - Full URL of the request to a CAP server for retrieving temporary credentials if authentication_type is cap.
  • snapmirror_use - Use of the cloud target if owner is snapmirror: data, metadata.
  • azure_msi_token - Azure Managed Service Identity (MSI) token if owner is fabricpool or snapmirror, provider_type is Azure_Cloud, authentication_type if specified must be azure_msi and platform is Azure Netapp Files.
  • authentication_type - Authentication used to access the target: key, cap, ec2_iam, gcp_sa, azure_msi.
  • ssl_enabled - SSL/HTTPS enabled or disabled.
  • port - Port number of the object store that ONTAP uses when establishing a connection.
  • ipspace - IPspace to use in order to reach the cloud target.
  • use_http_proxy - Use the HTTP proxy when connecting to the object store server.
  • azure_sas_token - Shared access signature to grant limited access to Azure storage account resources.
  • svm.name or svm.uuid - Name or UUID of SVM if owner is snapmirror.
  • read_latency_warning_threshold - Latency threshold to determine when to issue a warning alert EMS for a GET request.
Default property values
  • ec2_iam - if running in Cloud Volumes ONTAP in AWS
  • gcp_sa - if running in Cloud Volumes ONTAP in GCP
  • azure_msi - if running in Cloud Volumes ONTAP in Azure or if running on Azure NetApp Files platform with a Managed Service Identity (MSI) token.
  • key - in all other cases.
  • server
  • s3.amazonaws.com - if provider_type is AWS_S3
  • blob.core.windows.net - if provider_type is Azure_Cloud
  • storage.googleapis.com - if provider_type is GoogleCloud
  • ssl_enabled - true
  • port
  • 443 if ssl_enabled is true
  • 80 if ssl_enabled is false and provider_type is not SGWS
  • 8084 if ssl_enabled is false and provider_type is SGWS
  • ipspace - Default
  • certificate_validation_enabled - true
  • ignore_warnings - false
  • check_only - false
  • use_http_proxy - false
  • server_side_encryption
  • none - if provider_type is ONTAP_S3
  • sse_s3 - if provider_type is not ONTAP_S3
  • url_style
  • path_style - if provider_type is neither AWS_S3 nor AliCloud
  • virtual_hosted_style - if provider_type is either AWS_S3 or _AliCloud_
  • storage aggregate object-store config create
ignore_warnings
boolean
query
False
Specifies whether or not warning codes should be ignored.
check_only
boolean
query
False
Do not create the target configuration, only check that the POST request succeeds.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
access_key
string
Access key ID for AWS_S3 and other S3 compatible provider types.
authentication_type
string
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST.
azure_account
string
Azure account
azure_msi_token
string
Managed Service Identity (MSI) token required to authenticate to the Azure object store. This form of authentication is only supported on Azure NetApp Files.
azure_private_key
string
Azure access key
azure_sas_token
string
Shared access signature token to access Azure containers and blobs.
cap_url
string
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-password, and session token) for accessing the object store.
boolean
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
  • Introduced in: 9.6
  • x-nullable: true
cluster
cluster
container
string
Data bucket/container name. For FabricLink, a wildcard character "*" can also be specified to indicate that all the buckets in an SVM can use the same target information. However, for containers other than ONTAP, an exact name should be specified.
  • example: bucket1
  • readCreate: 1
  • x-nullable: true
ipspace
ipspace
name
string
Cloud target name
owner
string
Owner of the target. Allowed values are FabricPool, SnapMirror or S3_SnapMirror. A target can be used by only one feature.
port
integer
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
  • x-nullable: true
provider_type
string
Type of cloud provider. Allowed values depend on owner type. For FabricPool, AliCloud, AWS_S3, Azure_Cloud, GoogleCloud, IBM_COS, SGWS, and ONTAP_S3 are allowed. For SnapMirror, the valid values are AWS_S3 or SGWS. For FabricLink, AWS_S3, SGWS, S3_Compatible, S3EMU, LOOPBACK and ONTAP_S3 are allowed.
  • readCreate: 1
  • x-nullable: true
integer
The warning threshold for read latency that is used to determine when an alert ems for a read operation from an object store should be issued.
scope
string
If the cloud target is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.
secret_password
string
Secret access key for AWS_S3 and other S3 compatible provider types.
server
string
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3-.amazonaws.com, for example, s3-us-west-2.amazonaws.com. The region of the server and the bucket must match. For Azure, if the server is a "blob.core.windows.net" or a "blob.core.usgovcloudapi.net", then a value of azure-account followed by a period is added in front of the server.
string
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
  • enum: ["none", "sse_s3", "sse_kms", "dsse_kms"]
  • Introduced in: 9.7
  • x-nullable: true
snapmirror_use
string
Use of the cloud target by SnapMirror.
ssl_enabled
boolean
SSL/HTTPS enabled or not
svm
svm
This field is only applicable when used for SnapMirror and FabricLink. For POST and PATCH, SVM information is required for SnapMirror and FabricLink targets when the scope is svm and is not allowed for FabricPool targets. For GET, this field is not set if the scope of the cloud target is "cluster".
url_style
string
URL style used to access S3 bucket.
use_http_proxy
boolean
Use HTTP proxy when connecting to the object store.
used
integer
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes.
uuid
string
Cloud target UUID
Example request
  "access_key": "string",
  "authentication_type": "string",
  "azure_account": "string",
  "azure_msi_token": "string",
  "azure_private_key": "string",
  "azure_sas_token": "string",
  "cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
  "cluster": {
    "name": "string",
    "uuid": "string"
  "container": "bucket1",
  "ipspace": {
    "name": "Default",
  "name": "string",
  "owner": "string",
  "provider_type": "string",
  "scope": "string",
  "secret_password": "string",
  "server": "string",
  "server_side_encryption": "string",
  "snapmirror_use": "string",
  "svm": {
    "name": "svm1",
  "url_style": "string",
  "used": 0,
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
786436
VLDB is not running.
786908
Capability check failed.
787015
"encryption-key-id" is not expected when encrypt is false.
787016
An object store configuration with the same combination of server and container name already exists.
787020
Failed to check whether the FabricPool capability exists.
787021
The FabricPool capability is not enabled.
787030
Object store configuration creation is not supported in this cluster.
787036
Server name is invalid. A valid server name must be a fully qualified domain name.
787037
Cannot verify availability of the object store.
787038
Object store provider type requires a FabricPool license.
787039
Failed to retrieve FabricPool capacity license information.
787044
Cannot create object store configuration as the number of object stores in the cluster has reached maximum allowed limit.
787054
An object store configuration with the same combination of server, azure account and container name already exists.
787064
Object store server provider type does not match object store provider type. Use the provider type that matches the server.
787065
Certificate validation must be enabled for the object store provider.
787066
Certificate validation cannot be specified when the "-is-ssl-enabled" parameter is false.
787068
Disabling certificate validation requires an effective cluster version of ONTAP 9.4.0 or later.
787071
Object store configuration creation requires an effective cluster version of ONTAP 9.4.0 or later.
787082
Creating an object store configuration requires an effective cluster version of ONTAP 9.5.0 or later.
787089
The object store provider supports the virtual hosted-style, and the specified "-server" contains the container name. The container specified in the "-server" parameter must be the same as the name of the container specified in the "-container" parameter.
787133
Could not retrieve temporary credentials from the CAP server.
787134
Could not retrieve temporary credentials from the CAP server due to an unexpected response.
787136
Specifying "CAP" as the "-auth-type" requires an effective cluster version of ONTAP 9.5.0 or later.
787148
The clock on node is behind by more than the maximum of 5 minutes.
787149
The clock on node is ahead by more than the maximum of 5 minutes.
787158
787159
An object store configuration with the same name already exists.
787179
One or more clusters in this MetroCluster configuration do not have an effective cluster version of ONTAP 9.7.0 or later.
787184
Using HTTP proxies with FabricPool requires an effective cluster version of ONTAP 9.7.0 or later.
787185
There is no HTTP proxy for IPspace. Refer to the "vserver http-proxy" man page for details.
787188
Object store configuration belongs to another cluster and cannot be modified from the local cluster, unless the cluster is in switchover mode.
787189
Object store configuration name must not have the "-mc" suffix when the configuration is created for a local cluster. To create an object store configuration which belongs to another cluster, the cluster must be in switchover mode and "-cluster" must be specified.
787209
Object store is not accessible from the partner cluster in a MetroCluster configuration.
787216
Cannot perform object store configuration operations on a cluster that is waiting for switchback.
787222
Object store connectivity check failed on partner cluster in MetroCluster configuration. Wait a few minutes, and try the operation again.
787223
Specifying "GCP_SA" as the "-auth-type" requires an effective cluster version of ONTAP 9.7.0 or later.
787227
Specifying "Azure_MSI" as the "-auth-type" requires an effective cluster version of ONTAP 9.7 or later.
787228
SSL is required for this configuration.
787229
Cannot perform operation as URL style is not supported with object store provider type.
787233
The hash key for enabling this FabricPool feature is not present on the cluster.
787234
The hash key provided for the node to enable this FabricPool feature is not valid.
787254
The parameter is not supported on this system.
787257
The parameter "-encryption-context" is only applicable for AWS object store provider.
787262
The "create-container" option is applicable only for an SGWS or ONTAP_S3 object store provider.
787301
ONTAP S3 Bucket is of type NAS and is not supported as a target for FabricPool.
787302
Cannot use HTTP port with "-is-ssl-enabled" set to true.
787303
Cannot use HTTPS port with "-is-ssl-enabled" set to false.
787325
FabricPool is not supported on this platform.
787350
Creating an object store configuration with a Managed Service Identity (MSI) token is only supported on Azure NetApp files.
787351
Internal Error. Invalid authentication type.
787352
Creating an object store configuration with a Managed Service Identity (MSI) token requires an effective cluster version of ONTAP 9.16.1 or later.
787353
Creating an object store configuration with a Managed Service Identity (MSI) token is not supported for this owner.
787354
The specified properties are mutually exclusive.
787355
azure_msi authentication-type is only supported with Azure_Cloud provider-type.
45940761
Hostname cannot be resolved. Check the spelling of the hostname and check the system DNS availability using the "vserver services name-service dns check" command.
45940778
Bucket already exists.
139591795
Object store configuration for S3 SnapMirror representing ONTAP S3 object store provider only supports \"*\" as the container name.
139591796
Object store configuration name for S3 SnapMirror representing ONTAP S3 object store provider must be of the format \"vserver::\\\".
string
cluster
name
string
The name of the cluster that owns the cloud target. For POST, this accepts the name of the peer cluster only if the cluster is in switchover state.
uuid
string
The UUID of the cluster that owns the cloud target. For POST, this accepts the UUID of the peer cluster only if the cluster is in switchover state.
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
svm
name
string
uuid
string
cloud_target
access_key
string
authentication_type
string
azure_account
string
Azure account
azure_msi_token
string
azure_private_key
string
Azure access key
azure_sas_token
string
cap_url
string
boolean
  • x-nullable: true
cluster
cluster
container
string
  • example: bucket1
  • readCreate: 1
  • x-nullable: true
ipspace
ipspace
name
string
Cloud target name
owner
string
port
integer
  • x-nullable: true
provider_type
string
  • readCreate: 1
  • x-nullable: true
integer
scope
string
secret_password
string
server
string
string
  • x-nullable: true
snapmirror_use
string
ssl_enabled
boolean
svm
svm
url_style
string
use_http_proxy
boolean
used
integer
uuid
string
Cloud target UUID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
