Create a new IP to hostname mapping
Creates a new IP to hostname mapping to associate an IP address with a canonical hostname in an existing SVM. Use this when you need to manage DNS entries within your network configuration.
HTTP method and endpoint
POST /name-services/local-hosts
Introduced in
ONTAP 9.10
Required properties
owner.uuidorowner.name- Existing SVM in which to create IP to host mapping. -
address- IPv4/IPv6 address in dotted form. -
hostname- Canonical hostname.
Related ONTAP commands
vserver services name-service dns hosts create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
address |
string |
IPv4/IPv6 address in dotted form. |
aliases |
array[string] |
The list of aliases. |
hostname |
string |
Canonical hostname. |
owner |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
Example request
"address": "123.123.123.123",
"aliases": [
"host1.sales.foo.com",
"host2.sakes.foo.com"
"hostname": "host.sales.foo.com",
"owner": {
"name": "svm1",
"scope": "string"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966253 |
IPv6 is not enabled in the cluster. Enable IPv6 using command "network options ipv6 modify -enabled true" and try again. |
8912896 |
Only admin or data Vservers allowed. |
23724055 |
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support. |
href |
string |
_links
owner
name |
string |
The name of the SVM. |
uuid |
string |
local_host
address |
string |
aliases |
array[string] |
hostname |
string |
owner |
scope |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
