REST API reference
Create a new IP to hostname mapping
Creates an IP to hostname mapping, establishing a connection between an IP address and its corresponding hostname within an existing SVM. This is useful for managing network configurations and ensuring correct name resolution.
HTTP method and endpoint
POST /name-services/local-hosts
Introduced in
ONTAP 9.10
Usage notes
Creates a new IP to hostname mapping.
Required properties
  • owner.uuid or owner.name - Existing SVM in which to create IP to host mapping.
  • address - IPv4/IPv6 address in dotted form.
  • hostname - Canonical hostname.
  • vserver services name-service dns hosts create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
address
string
aliases
array[string]
The list of aliases.
hostname
string
Canonical hostname.
owner
owner
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "address": "123.123.123.123",
  "aliases": [
    "host1.sales.foo.com",
    "host2.sakes.foo.com"
  "hostname": "host.sales.foo.com",
  "owner": {
    "name": "svm1",
  "scope": "string"
Status: 201, Created
Status: Default, Error
string
owner
name
string
The name of the SVM.
uuid
string
local_host
address
string
aliases
array[string]
hostname
string
Canonical hostname.
owner
owner
scope
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
