REST API reference
Create a new IP to hostname mapping
Creates a new mapping between an IP address and a hostname. This is useful when you need to associate an IP address with a specific hostname for streamlined network management within your storage environment.
HTTP method and endpoint
POST /name-services/local-hosts
Introduced in
ONTAP 9.10
Usage notes
Creates a new IP to hostname mapping.
Required properties
  • owner.uuid or owner.name - Existing SVM in which to create IP to host mapping.
  • address - IPv4/IPv6 address in dotted form.
  • hostname - Canonical hostname.
  • vserver services name-service dns hosts create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
address
string
aliases
array[string]
The list of aliases.
hostname
string
Canonical hostname.
owner
owner
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "address": "123.123.123.123",
  "aliases": [
    "host1.sales.foo.com",
    "host2.sakes.foo.com"
  "hostname": "host.sales.foo.com",
  "owner": {
    "name": "svm1",
  "scope": "string"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1377682
IPv6 is not enabled in the cluster.
1966253
IPv6 is not enabled in the cluster. Enable IPv6 using command "network options ipv6 modify -enabled true" and try again.
2621706
The specified owner UUID is incorrect for the specified owner name.
8912896
Only admin or data Vservers allowed.
23724055
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support.
string
owner
name
string
uuid
string
local_host
address
string
aliases
array[string]
hostname
string
Canonical hostname.
owner
owner
scope
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
