Create a service policy for network interfaces
Creates a service policy for network interfaces to define specific settings and behaviors for managing network traffic. This is useful when you need to control how network resources are allocated and used within your system.
HTTP method and endpoint
POST /network/ip/service-policies
Introduced in
ONTAP 9.8
Required properties
name- Name of the service policy to create. -
ipspace.nameoripspace.uuid-
Required for cluster-scoped service policies.
Optional for SVM-scoped service policies.
svm.nameorsvm.uuid-
Required for SVM-scoped service policies.
Not valid for cluster-scoped service policies.
Default property values
If not specified in POST, the following default property values are assigned:
scope-
svm if the svm parameter is specified
cluster if the svm parameter is not specified
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
ipspace |
is_built_in |
boolean |
name |
string |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
services |
array[string] |
svm |
uuid |
string |
Example request
"ipspace": {
"name": "exchange",
"name": "default-intercluster",
"scope": "string",
"services": [
"data_nfs"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966373 |
Port must reside in the same IPspace as the interface's SVM. |
1967146 |
Svm.name does not exist. |
1967147 |
Svm.uuid does not exist. |
53281895 |
Custom service policies cannot be created on the specified svm |
53281929 |
Service policies cannot combine block and file services. |
53281931 |
Service policy names cannot start with "default-". |
53281932 |
Service cannot be added because the service does not exist for the specified SVM or IPspace. |
53281933 |
A Cluster-scoped service cannot be added to a SVM-scoped service policy. |
53281934 |
An SVM-scoped service cannot be added to a Cluster-scoped service policy. |
53281935 |
Scope is set to "svm" and svm.uuid or svm.name have not been specified. |
53281936 |
The SVM is not in the specified IPspace. |
53281937 |
Svm.uuid and svm.name are not valid parameters when scope is cluster. |
53281938 |
Svm.uuid or svm.name specify a vserver that does not exist. |
53281939 |
One or more of the svm.uuid, svm.name, ipspace.uuid, and ipspace.name have invalid values. |
53281940 |
SVM or IPspace has not been specified. |
53281941 |
SVM does not exist. |
53281944 |
Ipspace.name does not exist. |
53281945 |
Ipspace.uuid is not an IPspace. |
53281946 |
Service policy already exists. |
53281958 |
Service policies cannot contain multiple block-oriented services. |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
The name of the SVM. |
uuid |
string |
ip_service_policy
ipspace |
is_built_in |
boolean |
name |
string |
scope |
string |
services |
array[string] |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
