Create a service policy for network interfaces
POST /network/ip/service-policies
Introduced In: 9.8
Creates a service policy for network interfaces.
Related ONTAP commands
network interface service-policy create
Required properties
name- Name of the service policy to create. -
ipspace.nameoripspace.uuid-
Required for cluster-scoped service policies.
Optional for SVM-scoped service policies.
svm.nameorsvm.uuid-
Required for SVM-scoped service policies.
Not valid for cluster-scoped service policies.
Default property values
If not specified in POST, the following default property values are assigned:
scope-
svm if the svm parameter is specified
cluster if the svm parameter is not specified
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
ipspace |
is_built_in |
boolean |
name |
string |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
services |
array[string] |
svm |
uuid |
string |
Example request
"ipspace": {
"name": "exchange",
"name": "default-intercluster",
"scope": "string",
"services": [
"data_nfs"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966373 |
Port must reside in the same IPspace as the interface's SVM. |
1967146 |
Svm.name does not exist. |
1967147 |
Svm.uuid does not exist. |
2621740 |
An unexpected error when trying to determine whether the target Vserver was locked or not on this cluster. |
53281895 |
Custom service policies cannot be created on the specified svm |
53281929 |
Service policies cannot combine block and file services. |
53281931 |
Service policy names cannot start with "default-". |
53281932 |
Service cannot be added because the service does not exist for the specified SVM or IPspace. |
53281933 |
A Cluster-scoped service cannot be added to a SVM-scoped service policy. |
53281934 |
An SVM-scoped service cannot be added to a Cluster-scoped service policy. |
53281935 |
Scope is set to "svm" and svm.uuid or svm.name have not been specified. |
53281936 |
The SVM is not in the specified IPspace. |
53281937 |
Svm.uuid and svm.name are not valid parameters when scope is cluster. |
53281938 |
Svm.uuid or svm.name specify a vserver that does not exist. |
53281939 |
One or more of the svm.uuid, svm.name, ipspace.uuid, and ipspace.name have invalid values. |
53281940 |
SVM or IPspace has not been specified. |
53281941 |
SVM does not exist. |
53281944 |
Ipspace.name does not exist. |
53281945 |
Ipspace.uuid is not an IPspace. |
53281946 |
Service policy already exists. |
53281958 |
Service policies cannot contain multiple block-oriented services. |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
uuid |
string |
ip_service_policy
ipspace |
is_built_in |
boolean |
name |
string |
scope |
string |
services |
array[string] |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
