REST API reference
Create a service policy for network interfaces
POST /network/ip/service-policies
Introduced In: 9.8
Creates a service policy for network interfaces.
  • network interface service-policy create
Required properties
  • name - Name of the service policy to create.
  • ipspace.name or ipspace.uuid
    • Required for cluster-scoped service policies.
    • Optional for SVM-scoped service policies.
  • svm.name or svm.uuid
    • Required for SVM-scoped service policies.
    • Not valid for cluster-scoped service policies.
Default property values
If not specified in POST, the following default property values are assigned:
  • scope
    • svm if the svm parameter is specified
    • cluster if the svm parameter is not specified
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
ipspace
ipspace
is_built_in
boolean
name
string
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
services
array[string]
svm
svm
uuid
string
Example request
  "ipspace": {
    "name": "Default",
  "name": "default-intercluster",
  "scope": "string",
  "services": [
    "data_nfs"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
1966373
Port must reside in the same IPspace as the interface's SVM.
1967146
Svm.name does not exist.
1967147
Svm.uuid does not exist.
2621740
An unexpected error when trying to determine whether the target Vserver was locked or not on this cluster.
53281895
Custom service policies cannot be created on the specified svm
53281929
Service policies cannot combine block and file services.
53281931
Service policy names cannot start with "default-".
53281932
Service cannot be added because the service does not exist for the specified SVM or IPspace.
53281933
A Cluster-scoped service cannot be added to a SVM-scoped service policy.
53281934
An SVM-scoped service cannot be added to a Cluster-scoped service policy.
53281935
Scope is set to "svm" and svm.uuid or svm.name have not been specified.
53281936
The SVM is not in the specified IPspace.
53281937
Svm.uuid and svm.name are not valid parameters when scope is cluster.
53281938
Svm.uuid or svm.name specify a vserver that does not exist.
53281939
One or more of the svm.uuid, svm.name, ipspace.uuid, and ipspace.name have invalid values.
53281940
SVM or IPspace has not been specified.
53281941
SVM does not exist.
53281942
Service policy cannot be created because the specified SVM does not exist.
53281944
Ipspace.name does not exist.
53281945
Ipspace.uuid is not an IPspace.
53281946
Service policy already exists.
53281958
Service policies cannot contain multiple block-oriented services.
string
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
svm
name
string
uuid
string
ip_service_policy
ipspace
ipspace
is_built_in
boolean
name
string
scope
string
services
array[string]
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
