REST API reference
Create a LUN map
Creates a LUN map to associate a logical unit number with an existing initiator group and storage virtual machine, enabling access to the specified LUN.
HTTP method and endpoint
POST /protocols/san/lun-maps
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the LUN map.
  • igroup.uuid or igroup.name - Existing initiator group to map to the specified LUN.
  • lun.uuid or lun.name - Existing LUN to map to the specified initiator group.
Default property values
If not specified in POST, the following default property values are assigned.
  • logical_unit_number - If no value is provided, ONTAP assigns the lowest available value.
  • lun mapping create
additional_reporting_node.uuid
string
query
False
The unique identifier of an ONTAP cluster node to add to the default reporting nodes for the LUN map. The HA partner for the node is also added.
  • Introduced in: 9.10
additional_reporting_node.name
string
query
False
The name of an ONTAP cluster node to add to the default reporting nodes for the LUN map. The HA partner for the node is also added.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
igroup
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
  • example: 1
  • Max value: 4095
  • Min value: 0
  • Introduced in: 9.6
  • readCreate: 1
  • x-nullable: true
lun
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
reporting_nodes
array[reporting_nodes]
The cluster nodes from which network paths to the mapped LUNs are advertised via the SAN protocols as part of the Selective LUN Map (SLM) feature of ONTAP.
When a LUN map is created, the cluster node hosting the LUN and its high availability (HA) partner are set as the default reporting node. In POST, the property additional_reporting_node may be used to add an additional node and its HA partner.
  • readOnly: 1
svm
svm
Example request
  "igroup": {
    "initiators": [
      "iqn.1998-01.com.corp.iscsi:name1"
    "name": "igroup1",
    "os_type": "string",
    "protocol": "string",
    "uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
  "logical_unit_number": 1,
  "lun": {
    "name": "/vol/volume1/qtree1/lun1",
    "node": {
      "name": "node1",
      "uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
  "reporting_nodes": [
      "name": "node1",
      "uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[lun_map]
  "num_records": 1,
  "records": [
      "igroup": {
        "initiators": [
        "name": "igroup1",
      "lun": {
        "node": {
          "name": "node1",
          "name": "node1",
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1254207
The LUN is already mapped to the same initiator group.
2621462
The specified SVM does not exist or is not accessible to the caller.
2621706
Both the SVM UUID and SVM name were supplied, but don't refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5374053
The LUN is the destination of an ongoing restore operation and is inaccessible for I/O and management. Wait for the restore to complete and try the command again.
5374238
The operation is not allowed on a LUN in a Snapshot copy.
5374316
A LUN move operation is in progress on the source LUN.
5374329
A LUN of class vvol cannot be mapped.
5374573
A node has no interface configured with the iSCSI or Fibre Channel protocols for the specified SVM.
5374574
Multiple nodes have no interface configured with the iSCSI or Fibre Channel protocols for the specified SVM.
5374581
A node has no interface configured with the iSCSI protocol for the specified SVM.
5374582
Multiple nodes have no interface configured with the iSCSI protocol for the specified SVM.
5374583
A node has no interface configured with the Fibre Channel protocol for the specified SVM.
5374584
Multiple nodes have no interface configured with the Fibre Channel protocol for the specified SVM.
5374901
Either lun.uuid or lun.name must be provided to create a LUN map.
5374902
Either igroup.uuid or igroup.name must be provided to create a LUN map.
5374920
The cluster node specified in additional_reporting_node does not exist.
5374921
The cluster node name and UUID specified in additional_reporting_node do not refer to the same cluster node.
string
igroup
initiators
array[string]
The initiators that are members of the initiator group.
name
string
The name of the initiator group. Valid in POST.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group.
uuid
string
The unique identifier of the initiator group. Valid in POST.
node
The LUN node.
name
string
The name the LUN's node.
uuid
string
The unique identifier of the LUN node.
lun
name
string
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and file name of the LUN. Valid in POST.
node
node
The LUN node.
uuid
string
The unique identifier of the LUN. Valid in POST.
reporting_nodes
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
name
string
The name of the node.
Either uuid or name are required in POST.
uuid
string
The unique identifier of the node.
svm
name
string
The name of the SVM.
uuid
string
lun_map
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup
igroup
logical_unit_number
integer
  • example: 1
  • Max value: 4095
  • Min value: 0
  • readCreate: 1
  • x-nullable: true
lun
lun
reporting_nodes
  • readOnly: 1
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
