Create a LUN map
Creates a mapping between a LUN and an initiator group, enabling access to the LUN through the specified initiator group within an SVM. Utilize this when you need to configure access paths for LUNs in your storage environment.
HTTP method and endpoint
POST /protocols/san/lun-maps
Introduced in
ONTAP 9.6
Usage notes
Creates a LUN map.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the LUN map. -
igroup.uuidorigroup.name- Existing initiator group to map to the specified LUN. -
lun.uuidorlun.name- Existing LUN to map to the specified initiator group.
Default property values
If not specified in POST, the following default property values are assigned.
logical_unit_number- If no value is provided, ONTAP assigns the lowest available value.
Related ONTAP commands
lun mapping create
Learn more
additional_reporting_node.uuid |
string |
query |
False |
The unique identifier of an ONTAP cluster node to add to the default reporting nodes for the LUN map. The HA partner for the node is also added.
additional_reporting_node.name |
string |
query |
False |
The name of an ONTAP cluster node to add to the default reporting nodes for the LUN map. The HA partner for the node is also added.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
igroup |
The initiator group to which the LUN is mapped. Required in POST by supplying either the |
logical_unit_number |
integer |
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
lun |
The LUN to which the initiator group is mapped. Required in POST by supplying either the |
reporting_nodes |
array[reporting_nodes] |
The cluster nodes from which network paths to the mapped LUNs are advertised via the SAN protocols as part of the Selective LUN Map (SLM) feature of ONTAP. When a LUN map is created, the cluster node hosting the LUN and its high availability (HA) partner are set as the default reporting node. In POST, the property For further information, see DOC /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes .
svm |
Example request
"igroup": {
"initiators": [
"iqn.1998-01.com.corp.iscsi:name1"
"name": "igroup1",
"os_type": "string",
"protocol": "string",
"uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
"logical_unit_number": 1,
"lun": {
"name": "/vol/volume1/qtree1/lun1",
"node": {
"name": "node1",
"uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
"replicated": true,
"reporting_nodes": [
"name": "node1",
"uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[lun_map] |
"num_records": 1,
"records": [
"igroup": {
"initiators": [
"name": "igroup1",
"lun": {
"node": {
"name": "node1",
"replicated": true,
"name": "node1",
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254201 |
The specified LUN does not exist. |
1254207 |
The LUN is already mapped to the same initiator group. |
2621462 |
The specified SVM does not exist or is not accessible to the caller. |
2621706 |
Both the SVM UUID and SVM name were supplied, but don't refer to the same SVM. |
2621707 |
No SVM was specified. Either |
5374053 |
The LUN is the destination of an ongoing restore operation and is inaccessible for I/O and management. Wait for the restore to complete and try the command again. |
5374127 |
The specified LUN name is invalid. |
5374238 |
The operation is not allowed on a LUN in a snapshot. |
5374316 |
A LUN move operation is in progress on the source LUN. |
5374329 |
A LUN of class |
5374573 |
A node has no interface configured with the iSCSI or Fibre Channel protocols for the specified SVM. |
5374574 |
Multiple nodes have no interface configured with the iSCSI or Fibre Channel protocols for the specified SVM. |
5374581 |
A node has no interface configured with the iSCSI protocol for the specified SVM. |
5374582 |
Multiple nodes have no interface configured with the iSCSI protocol for the specified SVM. |
5374583 |
A node has no interface configured with the Fibre Channel protocol for the specified SVM. |
5374584 |
Multiple nodes have no interface configured with the Fibre Channel protocol for the specified SVM. |
5374652 |
An error was reported by the peer cluster while creating a replicated LUN map. The specific error will be included as a nested error. |
5374901 |
Either |
5374902 |
Either |
5374920 |
The cluster node specified in additional_reporting_node does not exist. |
5374921 |
The cluster node name and UUID specified in additional_reporting_node do not refer to the same cluster node. |
5376356 |
The LUN is part of a SnapMirror active sync relationship that has a different SVM peering relationship than the igroup. |
5376461 |
5376462 |
The specified LUN name is too long. |
href |
string |
_links
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
initiators |
array[string] |
The initiators that are members of the initiator group. |
name |
string |
The name of the initiator group. Valid in POST. |
os_type |
string |
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. |
protocol |
string |
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. |
replicated |
boolean |
This property reports if the initiator group is replicated. |
uuid |
string |
The unique identifier of the initiator group. Valid in POST. |
node
The LUN node.
name |
string |
The name of the LUN's node. |
uuid |
string |
The unique identifier of the LUN node. |
smbc
"Properties related to SM-BC replication."
replicated |
boolean |
This property reports if the LUN is replicated via SM-BC. |
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
name |
string |
The name of the LUN. Valid in POST. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume. LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
node |
The LUN node. |
smbc |
"Properties related to SM-BC replication." |
uuid |
string |
The unique identifier of the LUN. Valid in POST. |
reporting_nodes
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links |
name |
string |
The name of the node. Either |
uuid |
string |
The unique identifier of the node. Either |
svm
name |
string |
uuid |
string |
lun_map
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup |
integer |
lun |
reporting_nodes |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
