REST API reference
Create a LUN map
Creates a LUN map to associate a logical unit number (LUN) with an initiator group within an SVM. This mapping is essential for enabling access to the LUN from hosts configured in the initiator group.
HTTP method and endpoint
POST /protocols/san/lun-maps
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the LUN map.
  • igroup.uuid or igroup.name - Existing initiator group to map to the specified LUN.
  • lun.uuid or lun.name - Existing LUN to map to the specified initiator group.
Default property values
If not specified in POST, the following default property values are assigned.
  • logical_unit_number - If no value is provided, ONTAP assigns the lowest available value.
  • lun mapping create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
igroup
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
  • example: 1
  • Max value: 4095
  • Min value: 0
  • Introduced in: 9.6
  • readCreate: 1
lun
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
svm
svm
Example request
  "igroup": {
    "initiators": [
      "iqn.1998-01.com.corp.iscsi:name1"
    "name": "igroup1",
    "os_type": "string",
    "protocol": "string",
    "uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
  "logical_unit_number": "1",
  "lun": {
    "name": "/vol/volume1/qtree1/lun1",
    "node": {
      "name": "node1",
      "uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records.
records
array[lun_map]
  "records": [
      "igroup": {
        "initiators": [
        "name": "igroup1",
      "lun": {
        "node": {
          "name": "node1",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
1254207
The LUN is already mapped to the same initiator group.
2621462
The specific SVM does not exist.
2621706
Both the SVM UUID and SVM name were supplied, but don't refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5374053
The LUN is the destination of an ongoing restore operation and is inaccessible for I/O and management. Wait for the restore to complete and try the command again.
5374238
The operation is not allowed on a LUN in a Snapshot copy.
5374316
A LUN move operation is in progress on the source LUN.
5374329
A LUN of class vvol cannot be mapped.
5374573
A node has no interface configured with the iSCSI or Fibre Channel protocols for the specified SVM.
5374574
Multiple nodes have no interface configured with the iSCSI or Fibre Channel protocols for the specified SVM.
5374581
A node has no interface configured with the iSCSI protocol for the specified SVM.
5374582
Multiple nodes have no interface configured with the iSCSI protocol for the specified SVM.
5374583
A node has no interface configured with the Fibre Channel protocol for the specified SVM.
5374584
Multiple nodes have no interface configured with the Fibre Channel protocol for the specified SVM.
5374901
Either lun.uuid or lun.name must be provided to create a LUN map.
5374902
Either igroup.uuid or igroup.name must be provided to create a LUN map.
string
igroup
initiators
array[string]
The initiators that are members of the initiator group.
name
string
The name of the initiator group. Valid in POST.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group.
uuid
string
The unique identifier of the initiator group. Valid in POST.
node
The LUN node.
name
string
The name the LUN's node.
uuid
string
The unique identifier of the LUN node.
lun
name
string
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and file name of the LUN. Valid in POST.
node
node
The LUN node.
uuid
string
The unique identifier of the LUN. Valid in POST.
svm
name
string
The name of the SVM.
uuid
string
lun_map
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup
igroup
logical_unit_number
integer
  • example: 1
  • Max value: 4095
  • Min value: 0
  • readCreate: 1
lun
lun
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
