Create an authentication key
Creates an authentication key to manage secure interactions with external systems. Use this endpoint when you need to establish or update secure access credentials.
HTTP method and endpoint
POST /security/key-managers/{security_key_manager.uuid}/auth-keys
Introduced in
ONTAP 9.12
Related ONTAP commands
security key-manager key create
Required properties
security_key_manager.uuid- UUID of the external key manager.
security_key_manager.uuid |
string |
path |
True |
External key manager UUID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_id |
string |
Key identifier. |
key_tag |
string |
Optional parameter to define key-tag for the authentication key, length 0-32 characters. |
passphrase |
string |
Authentication passphrase, length 20-32 characters. May contain the '=' character. |
Example request
"key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
"key_tag": "Authentication-Key-01",
"passphrase": "AuthenticationKey_01"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[key_manager_auth_key] |
"records": [
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536048 |
The maximum number of authentication keys are already configured. |
65536053 |
Invalid passphrase length; passphrase must be 20-32 ASCII-range characters. |
65536056 |
The key tag value provided contains invalid characters. |
65536056 |
The key-tag option cannot contain any spaces, tabs or new lines. |
65536074 |
No key servers found. |
65536076 |
Failed to push authentication key to any registered key servers. |
65536160 |
Unable to determine the current number of configured authentication keys. |
65536264 |
Failed to create authentication key. |
65536265 |
Failed to create a key-id for the authentication key. |
65536828 |
External key management is not enabled for the SVM. |
65536856 |
65536872 |
Error cleaning up key database after key creation error. |
65536896 |
External key management is not configured on the partner site. |
65538800 |
External KMIP DKMIP keymanager not configured on administrative Vserver. |
65538801 |
Internal error while accessing keymanager database. |
65538802 |
The UUID provided is not associated with the administrator SVM key manager. |
66060289 |
Failed to store authentication key on key server. |
66060304 |
Invalid key length. |
href |
string |
self_link
key_id |
string |
Key identifier. |
key_tag |
string |
passphrase |
string |
_links
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
