Create an authentication key
Creates an authentication key for secure interactions with external services. Use this endpoint to generate a new key when integrating with an external key manager.
HTTP method and endpoint
POST /security/key-managers/{security_key_manager.uuid}/auth-keys
Introduced in
ONTAP 9.12
Related ONTAP commands
security key-manager key create
Required properties
security_key_manager.uuid- UUID of the external key manager.
security_key_manager.uuid |
string |
path |
True |
External key manager UUID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_id |
string |
Key identifier. |
key_tag |
string |
Optional parameter to define key-tag for the authentication key, length 0-32 characters. |
passphrase |
string |
Authentication passphrase, length 20-32 characters. May contain the '=' character. |
Example request
"key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
"key_tag": "Authentication-Key-01",
"passphrase": "AuthenticationKey_01"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[key_manager_auth_key] |
"records": [
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536048 |
The maximum number of authentication keys are already configured. |
65536053 |
Invalid passphrase length; passphrase must be 20-32 ASCII-range characters. |
65536056 |
The key tag value provided contains invalid characters. |
65536056 |
The key-tag option cannot contain any spaces, tabs or new lines. |
65536076 |
Failed to push authentication key to any registered key servers. |
65536160 |
Unable to determine the current number of configured authentication keys. |
65536264 |
Failed to create authentication key. |
65536265 |
Failed to create a key-id for the authentication key. |
65536828 |
External key management is not enabled for the SVM. |
65536856 |
No key servers found for the SVM. |
65536872 |
Error cleaning up key database after key creation error. |
65536896 |
External key management is not configured on the partner site. |
65538800 |
External KMIP DKMIP keymanager not configured on administrative Vserver. |
65538801 |
Internal error while accessing keymanager database. |
65538802 |
The UUID provided is not associated with the administrator SVM key manager. |
66060289 |
Failed to store authentication key on key server. |
66060304 |
Invalid key length. |
href |
string |
self_link
key_id |
string |
Key identifier. |
key_tag |
string |
passphrase |
string |
_links
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
