REST API reference
Create an authentication key
Creates an authentication key to establish secure communication with an external key manager. Use this operation when configuring encryption services.
HTTP method and endpoint
POST /security/key-managers/{security_key_manager.uuid}/auth-keys
Introduced in
ONTAP 9.12
  • security key-manager key create
Required properties
  • security_key_manager.uuid - UUID of the external key manager.
string
path
True
External key manager UUID
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
key_id
string
Key identifier.
key_tag
string
Optional parameter to define key-tag for the authentication key, length 0-32 characters.
passphrase
string
Authentication passphrase, length 20-32 characters. May contain the '=' character.
Security key manager object reference.
Example request
  "key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
  "key_tag": "Authentication-Key-01",
  "passphrase": "AuthenticationKey_01",
  "security_key_manager": {
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
Status: 201, Created
num_records
integer
Number of records
records
array[key_manager_auth_key]
  "records": [
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
65536048
The maximum number of authentication keys are already configured.
65536053
Invalid passphrase length; passphrase must be 20-32 ASCII-range characters.
65536056
The key tag value provided contains invalid characters.
65536056
The key-tag option cannot contain any spaces, tabs or new lines.
65536076
Failed to push authentication key to any registered key servers.
65536160
Unable to determine the current number of configured authentication keys.
65536264
Failed to create authentication key.
65536265
Failed to create a key-id for the authentication key.
65536828
External key management is not enabled for the SVM.
65536856
No key servers found for the SVM.
65536872
Error cleaning up key database after key creation error.
65536896
External key management is not configured on the partner site.
65536987
One or more key servers are unavailable.
65538800
External KMIP DKMIP keymanager not configured on administrative Vserver.
65538801
Internal error while accessing keymanager database.
65538802
The UUID provided is not associated with the administrator SVM key manager.
66060289
Failed to store authentication key on key server.
66060304
Invalid key length.
string
uuid
string
Key manager UUID
key_id
string
Key identifier.
key_tag
string
passphrase
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
