Retrieves and restores any current unrestored keys (associated with the storage controller) from the specified key management server
the uuid of the external key manager can be retrieved using [get /api/security/key-managers]
# related ontap commands
* security key-manager external restore
POST /security/key-managers/{security_key_manager.uuid}/restore
Introduced In: 9.13
Retrieves and restores any current unrestored keys (associated with the storage controller) from the specified key management server.
Required properties
security_key_manager.uuid- UUID of the key management server. The UUID of the external key manager can be retrieved using [GET /api/security/key-managers].
Related ONTAP commands
security_key_manager.uuid |
string |
path |
True |
Key manager UUID. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_id |
string |
Key identifier. |
key_server |
string |
External key server for key management. |
key_tag |
string |
Additional information associated with the key. |
node |
Example request
"key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
"key_server": "keyserver1.com:5698",
"key_tag": "Authentication-Key-01",
"node": {
"name": "node1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536083 |
Internal error. Failed to restore the authentication key. |
65536843 |
The key management server is not configured for the SVM. |
65536855 |
Internal error. Failed to restore the volume encryption key. |
65538500 |
This command only restores keys from primary key servers. |
href |
string |
_links
node
name |
string |
uuid |
string |
security_key_manager_restore_keys
key_id |
string |
Key identifier. |
key_server |
string |
key_tag |
string |
node |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
