REST API reference
Retrieve and restore unrestored keys
POST /security/key-managers/{security_key_manager.uuid}/restore
Introduced In: 9.13
Retrieves and restores any current unrestored keys (associated with the storage controller) from the specified key management server.
Required properties
  • security_key_manager.uuid - UUID of the key management server. The UUID of the external key manager can be retrieved using [GET /api/security/key-managers].
  • security key-manager external restore
string
path
True
Key manager UUID.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
key_id
string
Key identifier.
key_server
string
External key server for key management.
key_tag
string
Additional information associated with the key.
node
node
Example request
  "key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
  "key_server": "keyserver1.com:5698",
  "key_tag": "Authentication-Key-01",
  "node": {
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
65536083
Internal error. Failed to restore the authentication key.
65536843
The key management server is not configured for the SVM.
65536855
Internal error. Failed to restore the volume encryption key.
65538500
This command only restores keys from primary key servers.
string
node
uuid
string
security_key_manager_restore_keys
key_id
string
Key identifier.
key_server
string
key_tag
string
node
node
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
