Retrieve and restore unrestored keys
Retrieves and restores any unrestored keys from the specified key management server. This operation is used when you need to manage key restoration associated with the storage controller.
HTTP method and endpoint
POST /security/key-managers/{security_key_manager.uuid}/restore
Introduced in
ONTAP 9.13
Usage notes
Retrieves and restores any current unrestored keys (associated with the storage controller) from the specified key management server.
Required properties
security_key_manager.uuid- UUID of the key management server. The UUID of the external key manager can be retrieved using [GET /api/security/key-managers].
Related ONTAP commands
security key-manager external restore
security_key_manager.uuid |
string |
path |
True |
Key manager UUID. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_id |
string |
Key identifier. |
key_server |
string |
External key server for key management. |
key_tag |
string |
Additional information associated with the key. |
node |
Example request
"key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
"key_server": "keyserver1.com:5698",
"key_tag": "Authentication-Key-01",
"node": {
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536083 |
Internal error. Failed to restore the authentication key. |
65536843 |
The key management server is not configured for the SVM. |
65536855 |
Internal error. Failed to restore the volume encryption key. |
65538500 |
This command only restores keys from primary key servers. |
href |
string |
_links
node
uuid |
string |
security_key_manager_restore_keys
key_id |
string |
Key identifier. |
key_server |
string |
key_tag |
string |
node |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
