REST API reference
Start a legal-hold operation
Initiates a legal-hold operation to preserve specified files for litigation purposes. This is typically used when you need to ensure data is retained and protected in compliance with legal requirements.
HTTP method and endpoint
POST /storage/snaplock/litigations
Introduced in
ONTAP 9.7
Usage notes
Starts a Legal-Hold.
Required properties
  • path - Path of the file.
  • name - Litigation name.
  • volume.name or volume.uuid - Name or UUID of the volume.
  • snaplock legal-hold begin
Example
POST "/api/storage/snaplock/litigations" '{"volume.name":"SLC1","name":"l3","path":"/b.txt"}'
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
id
string
Specifies the litigation ID.
name
string
Specifies the legal-hold litigation name.
operations
array[snaplock_legal_hold_operation]
path
string
Specifies the path on which legal-hold operation has to be applied.
svm
svm
volume
volume
Example request
  "id": "string",
  "name": "lit1",
  "operations": [
      "id": 16842759,
      "num_files_failed": 0,
      "num_files_processed": 30,
      "num_files_skipped": 10,
      "num_inodes_ignored": 10,
      "path": "/dir1",
      "state": "completed"
  "path": "/dir1",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: 201, Created
id
string
name
string
operations
path
string
svm
svm
volume
volume
  "id": "string",
  "name": "lit1",
  "operations": [
      "id": 16842759,
      "path": "/dir1",
  "path": "/dir1",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response codes
Error code Description
14090346
Internal Error. Wait a few minutes, then try the command again
14090340
{field} is a required field
14090343
Invalid Field
14090641
The specified volume.name and volume.uuid refer to different volumes
string
id
integer
Operation ID.
num_files_failed
string
Specifies the number of files on which legal-hold operation failed.
num_files_processed
string
Specifies the number of files on which legal-hold operation was successful.
num_files_skipped
string
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.
num_inodes_ignored
string
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
path
string
Specifies the path on which legal-hold operation is applied.
state
string
Specifies the status of legal-hold operation.
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snaplock_litigation
id
string
name
string
operations
path
string
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
