Start a legal-hold operation
POST /storage/snaplock/litigations
Introduced In: 9.7
Starts a Legal-Hold.
Required properties
path- Path of the file. -
name- Litigation name. -
volume.nameorvolume.uuid- Name or UUID of the volume.
Related ONTAP commands
snaplock legal-hold begin
Example
POST "/api/storage/snaplock/litigations" '{"volume.name":"SLC1","name":"l3","path":"/b.txt"}'
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
id |
string |
Specifies the litigation ID. |
name |
string |
Specifies the legal-hold litigation name. |
operations |
path |
string |
Specifies the path on which legal-hold operation has to be applied. |
svm |
volume |
Example request
"id": "string",
"name": "lit1",
"operations": [
"id": 16842759,
"num_files_failed": 0,
"num_files_processed": 30,
"num_files_skipped": 10,
"num_inodes_ignored": 10,
"path": "/dir1",
"state": "completed",
"type": "begin"
"path": "/dir1",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response codes
| Error code | Description |
13762586 |
Volume is not a SnapLock Compliance volume |
13763162 |
Audit logging is not configured for the SVM |
13763280 |
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation. |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
14090340 |
{field} is a required field |
14090343 |
Invalid Field |
14090641 |
The specified volume.name and volume.uuid refer to different volumes |
href |
string |
_links
snaplock_legal_hold_operation
id |
integer |
Operation ID. |
num_files_failed |
string |
Specifies the number of files on which legal-hold operation failed. |
num_files_processed |
string |
Specifies the number of files on which legal-hold operation was successful. |
num_files_skipped |
string |
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation. |
num_inodes_ignored |
string |
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files. |
path |
string |
Specifies the path on which legal-hold operation is applied. |
state |
string |
Specifies the status of legal-hold operation. |
type |
string |
Specifies the type of legal-hold operation. |
svm
name |
string |
uuid |
string |
volume
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
snaplock_litigation
id |
string |
name |
string |
operations |
path |
string |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
