REST API reference
Start a legal-hold operation
Initiates a legal hold operation to preserve data in compliance with regulatory requirements. This is typically used to prevent deletion or modification of data during a formal investigation or litigation process.
HTTP method and endpoint
POST /storage/snaplock/litigations
Introduced in
ONTAP 9.7
Usage notes
Starts a Legal-Hold.
Required properties
  • path - Path of the file.
  • name - Litigation name.
  • volume.name or volume.uuid - Name or UUID of the volume.
  • snaplock legal-hold begin
Example
POST "/api/storage/snaplock/litigations" '{"volume.name":"SLC1","name":"l3","path":"/b.txt"}'
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
id
string
Specifies the litigation ID.
name
string
Specifies the legal-hold litigation name.
operations
array[snaplock_legal_hold_operation]
path
string
Specifies the path on which legal-hold operation has to be applied.
svm
svm
volume
volume
Example request
  "id": "string",
  "name": "lit1",
  "operations": [
      "id": "16842759",
      "num_files_failed": "0",
      "num_files_processed": "30",
      "num_files_skipped": "10",
      "num_inodes_ignored": "10",
      "path": "/dir1",
      "state": "completed"
  "path": "/dir1",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: 201, Created
id
string
name
string
operations
path
string
svm
svm
volume
volume
  "id": "string",
  "name": "lit1",
  "operations": [
      "id": "16842759",
      "path": "/dir1",
  "path": "/dir1",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
14090346
Internal Error. Wait a few minutes, then try the command again
14090340
{field} is a required field
14090343
Invalid Field
14090641
The specified volume.name and volume.uuid refer to different volumes
string
id
integer
Operation ID.
num_files_failed
string
Specifies the number of files on which legal-hold operation failed.
num_files_processed
string
Specifies the number of files on which legal-hold operation was successful.
num_files_skipped
string
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.
num_inodes_ignored
string
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
path
string
Specifies the path on which legal-hold operation is applied.
state
string
Specifies the status of legal-hold operation.
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snaplock_litigation
id
string
name
string
operations
path
string
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
