Cluster NTP keys endpoint overview
Overview
You can configure NTP to use shared private keys between ONTAP and trusted external NTP time servers.
You acquire the keys from the external NTP time servers and individual entries created for each unique key. You can use the /cluster/ntp/servers API to associate a key with an external NTP time server used by ONTAP and enable authentication.
Fields used for adding an NTP shared key
The required fields are:
id
digest_type
secret_key
Example
# Body create_ntp_key.txt(body): { "id": 10, "digest_type": "sha1", "value": "da39a3ee5e6b4b0d3255bfef95601890afd80709" } # Request curl -X POST "https://<mgmt-ip>/api/cluster/ntp/keys" -d "@create_ntp_key.txt"
