Manage cluster NTP keys
Configure NTP to use shared private keys with trusted external time servers. Use these endpoints to acquire keys and associate them with external NTP servers, enhancing authentication for time synchronization.
Overview
You can configure NTP to use shared private keys between ONTAP and trusted external NTP time servers.
You acquire the keys from the external NTP time servers and individual entries created for each unique key. You can use the /cluster/ntp/servers API to associate a key with an external NTP time server used by ONTAP and enable authentication.
Fields used for adding an NTP shared key
The required fields are:
id -
digest_type -
secret_key
Example
# Body
create_ntp_key.txt(body):
"id": 10,
"digest_type": "sha1",
"value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
# Request
curl -X POST "https://<mgmt-ip>/api/cluster/ntp/keys" -d "@create_ntp_key.txt"
