Delete a cloud target
Removes a specified cloud target, initiating a job and providing a link to monitor its progress.
HTTP method and endpoint
DELETE /cloud/targets/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the cloud target specified by the UUID. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate object-store config delete
uuid |
string |
path |
True |
Cloud target UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
787013 |
Cannot delete object store configuration as the store is attached to one or more aggregates. |
787014 |
Cannot delete object store configuration as there are objects in the store. |
787078 |
Cannot delete object store configuration. |
787188 |
Object store configuration belongs to another cluster and cannot be modified from the local cluster, unless the cluster is in switchover mode. |
787216 |
Cannot perform object store configuration operations on a cluster that is waiting for switchback. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
