REST API reference
Delete a cloud target
Deletes a specified cloud target, initiating a job and providing a link to monitor its progress.
HTTP method and endpoint
DELETE /cloud/targets/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the cloud target specified by the UUID. This request starts a job and returns a link to that job.
  • storage aggregate object-store config delete
uuid
string
path
True
Cloud target UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
