REST API reference
Delete a cloud target
Removes a specified cloud target, initiating a job and providing a link to monitor its progress.
HTTP method and endpoint
DELETE /cloud/targets/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the cloud target specified by the UUID. This request starts a job and returns a link to that job.
  • storage aggregate object-store config delete
uuid
string
path
True
Cloud target UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
787013
Cannot delete object store configuration as the store is attached to one or more aggregates.
787014
Cannot delete object store configuration as there are objects in the store.
787078
Cannot delete object store configuration.
787188
Object store configuration belongs to another cluster and cannot be modified from the local cluster, unless the cluster is in switchover mode.
787216
Cannot perform object store configuration operations on a cluster that is waiting for switchback.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
