REST API reference
Delete an Ethernet switch
Deletes an Ethernet switch entry from the configuration, typically when you need to remove a switch that is no longer in use.
HTTP method and endpoint
DELETE /network/ethernet/switches/{name}
Introduced in
ONTAP 9.11
  • system switch ethernet delete
name
string
path
True
Switch Name.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
