Delete an Ethernet switch
Deletes an Ethernet switch to remove it from the network configuration. Use this operation when you no longer need the switch in your network setup.
HTTP method and endpoint
DELETE /network/ethernet/switches/{name}
Introduced in
ONTAP 9.11
Related ONTAP commands
system switch ethernet delete
Learn more
name |
string |
path |
True |
Switch Name. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12517412 |
Cannot remove a discovered switch. To stop monitoring the switch, set " |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
