REST API reference
Delete an Ethernet switch
Deletes an Ethernet switch to remove its configuration and connections from the network setup. This operation is typically used when you need to decommission or replace a switch in your system.
HTTP method and endpoint
DELETE /network/ethernet/switches/{name}
Introduced in
ONTAP 9.11
  • system switch ethernet delete
name
string
path
True
Switch Name.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
