REST API reference
Delete an FPolicy persistent store configuration for an SVM
Deletes a specific FPolicy persistent store configuration for an SVM, removing the associated data store settings.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
Introduced in
ONTAP 9.14
  • fpolicy persistent-store delete
name
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
Error Code Description
9765064
Persistent store is active on atleast one policy
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
