REST API reference
Delete an FPolicy persistent store configuration for an SVM
Deletes a specific FPolicy Persistent Store configuration for an SVM. This action is typically used when you need to remove outdated or unnecessary configurations.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
Introduced in
ONTAP 9.14
Usage notes
Important notes: An option has been provided to delete the associated volume.
  • fpolicy persistent-store delete
name
string
path
True
delete_volume
boolean
query
False
Delete the associated volume of the Persistent Store.
  • Introduced in: 9.15
  • Default value:
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
Error Code Description
9765064
Persistent Store is active on at least one policy
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
