Delete an FPolicy persistent store configuration for an SVM
Deletes a specific FPolicy persistent store configuration for an SVM. This operation is typically used when you need to remove outdated or unnecessary configurations from the system.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
Introduced in
ONTAP 9.14
Usage notes
Important notes: An option has been provided to delete the associated volume.
Related ONTAP commands
fpolicy persistent-store delete
name |
string |
path |
True |
delete_volume |
boolean |
query |
False |
Delete the associated volume of the Persistent Store.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
| Error Code | Description |
9765064 |
Persistent store is active on atleast one policy |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
