REST API reference
Delete an export policy rule
DELETE /protocols/nfs/export-policies/{policy.id}/rules/{index}
Introduced In: 9.6
Deletes an export policy rule.
  • vserver export-policy rule delete
policy.id
integer
path
True
Export Policy ID
index
integer
path
True
Export Rule Index
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1703945
Ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted
1703946
Cannot determine if the ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted
1703954
Export policy does not exist
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
