Delete an export policy rule
DELETE /protocols/nfs/export-policies/{policy.id}/rules/{index}
Deletes an export policy rule.
Related ONTAP commands
vserver export-policy rule delete
Learn more
policy.id |
integer |
path |
True |
index |
integer |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703945 |
Ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted |
1703946 |
Cannot determine if the ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted |
1703954 |
Export policy does not exist |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
