REST API reference
Delete the S3 server configuration for an SVM
Deletes the S3 server configuration for a storage virtual machine (SVM). Use this endpoint when you need to remove the S3 server, S3 users, and buckets, depending on your specified parameters.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}
Introduced in
ONTAP 9.7
Usage notes
Deletes the S3 server configuration of an SVM. If the 'delete_all' parameter is set to false, only the S3 server is deleted. Otherwise S3 users and buckets present on the SVM are also deleted. Note that only empty buckets can be deleted. This endpoint returns the S3 server delete job-uuid in response. To monitor the job status follow /api/cluster/jobs/.
  • vserver object-store-server delete
delete_all
boolean
query
False
Delete S3 server and associated users and empty buckets.
  • Default value: 1
svm.uuid
string
path
True
Status: 200, Ok
Name Type Description
num_records
integer
Number of Records
records
array[records]
  "num_records": 1,
  "records": [
      "job": {
            "href": "/api/resourcelink"
        "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
92405864
An error occurs when deleting an S3 user or bucket. The reason for failure is detailed in the error message. Follow the error codes specified for the user or bucket endpoints to see details for the failure.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
records
job
job_link
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
