Delete the S3 server configuration for an SVM
Deletes the S3 server configuration for an SVM. Use this when you need to remove the S3 server, and optionally, all associated S3 users and buckets.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}
Introduced in
ONTAP 9.7
Usage notes
Deletes the S3 server configuration of an SVM. If the 'delete_all' parameter is set to false, only the S3 server is deleted. Otherwise S3 users and buckets present on the SVM are also deleted. Note that only empty buckets can be deleted. This endpoint returns the S3 server delete job-uuid in response. To monitor the job status follow /api/cluster/jobs/
Related ONTAP commands
vserver object-store-server delete
Learn more
delete_all |
boolean |
query |
False |
Delete S3 server and associated users and empty buckets.
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405864 |
An error occurs when deleting an S3 user or bucket. The reason for failure is detailed in the error message. Follow the error codes specified for the user or bucket endpoints to see details for the failure. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
