Delete the S3 server configuration for an SVM
DELETE /protocols/s3/services/{svm.uuid}
Deletes the S3 server configuration of an SVM. If the 'delete_all' parameter is set to false, only the S3 server is deleted. Otherwise S3 users and buckets present on the SVM are also deleted. Note that only empty buckets can be deleted. This endpoint returns the S3 server delete job-uuid in response. To monitor the job status follow /api/cluster/jobs/
Related ONTAP commands
vserver object-store-server delete
Learn more
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
delete_all |
boolean |
query |
False |
Delete S3 server and associated users and empty buckets.
Status: 200, Ok
| Name | Type | Description |
num_records |
integer |
Number of Records |
records |
array[records] |
"records": [
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405864 |
An error occurs when deleting an S3 user or bucket. The reason for failure is detailed in the error message. Follow the error codes specified for the user or bucket endpoints to see details for the failure. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
records
job |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
